2014-03-09, 12:01
2014-03-11, 16:11
Try googling for 'flirc', which will get you to links where to buy, and also to the site for software and configuring
2014-03-16, 00:47
I have a flirc device sitting here, works brilliantly (and easily) running on a MacBook Air or on a RaspberryPi with XBMC. The only issue I have had with mine is that it's single key press so you you can't hold a button to scroll (it only registers as one tap).
I recently got a cheap USB MCE remote and receiver from eBay for ~AU$7, plugs in and just works on the MBA, rPi and my Android XBMC installs.
