Hello folks!
I created Gotham version of Super Subtitles addon.
Big thanks to Super Subtitles Admins for for their help and support.
Latest zip (
releases) &
Source
NOTE: Only for TV shows.
Please report if you notice any strange things.
Also feel free to send me pull requests
Please consider adding it to xbmc official repo once you are happy with it and have done sufficient testing
Thanks and keep up the good work!
Big thanks!
But there seems to be some problem.
screen grab
always test using confluence skin, thats only way to know that its not issue with the skin you are using
It looks fine for me.
screenshot
I pushed a new version some min ago (the zip link is the same).
Please, try it out. Maybe it helps
(2014-03-12, 21:00)syluccy Wrote: [ -> ]Big thanks!
Still not working.
But maybe the problem is about the XBMC build.
Which one is the recommended?
I use the latest nightly xbmc on my developer machine (linux mint 16)
After your reply I tried with
RaspBMC XBMC test build 0306b and I got the same error. :S
But I pushed a new version to github. It worked as expected on my raspbmc.
Let's take an another try
Thanks for your help.
lets see
Debug Log using confluence skin please
I tried with a freshly installed win 8.1 with lastest xbmc nightly and everything works fine for me.
Do you use win 7 or win 8?
(2014-03-13, 23:11)syluccy Wrote: [ -> ]Ehh, still not working.
I've updateed my XBMC for the latest nightly XBMC, using this link.
http://mirrors.xbmc.org/nightlies/win32/
But still got the error message.
Yeap, the debug log is good idea. Thanks.
(2014-03-14, 00:00)amet Wrote: [ -> ]lets see Debug Log using confluence skin please
Thanks. I think you(r xbmc) do not use the latest (at this time 0.0.5) version of this plugin.
Some times I also noticed that xbmc does not like the same filename for different releases.
You select a new zip from the menu, but xbmc uses the old (with the same name) :S
I changed my "release mechanism" to use github's tags downloading feature.
The new link:
0.0.6
Before you are going to install the 0.0.6 version, please remove the old one.
Please let me know, if anything goes wrong.
(2014-03-15, 12:03)syluccy Wrote: [ -> ]Confluence skin, latest XBMC release, here you go!
http://xbmclogs.com/show.php?id=149496
Good to hear.
Thanks for your feedbacks.
(2014-03-15, 15:56)syluccy Wrote: [ -> ]Fuckin' A!
It's working.
You're great!
Hallelujah.
BTW, if you'll thinking about new features in the future:
- language priorisation
- download first synced subtitle
Features would be great.
I really liked the, in the default v12 XBMC subtitle add-on.
