2014-03-10, 01:06
XBMC Gotham version 13 beta 1
Run on Allwinner A10 chipset - 1024mb ram
Mali 400 GPU
Android 4.0.4
It did run fine yesterday, then I shut of my Android TV box, turned it on the today and it won't run anymore.
Cleaned cache, removed it, reinstall of the apk, no use. Won't start anymore.
When I clean the cache it fills the progress bar "preparing for first start" then it shuts down. When I click the app icon again it does not work.
Already cleaned out the memory, reboot of the tv box.
Other problems when it did work:
Lip sync errors, no HD decoding (SD worked).
Too bad it does not work anymore now, so I can provide a log.
Mali 400 GPU
Android 4.0.4
