I like this skin, but something I use is to see the forecast, and with this skin, using all the weather providers, I can't see the forecast, only the current conditions.
This skin only works for USA?
Thank you very much
I get the same issue here in Thailand
Are you using weather underground?
(2014-07-11, 22:14)Mr_Brownstone Wrote: [ -> ]Are you using weather underground?
Thanks, being in the UK, it made sense to me to select the Met Office as my weather source but I was having the same problem as everyone else here. I've switched to Weather Underground and now it works. Is this by design? Is Ace/AeonMQ written with support only for WU?
beeswax, yes only work with WU in MQ5 and Ace (because it´s default weather service for long time in XBMC).
