Full Version: XBMC Adult 18+ Add-on Repository
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
"Does anyone else using an Apple TV 2 with Gotham 13.0.0 Mar29.14 build Get the following issues:
Either when clicking on some sites ie Empflix, I get "Error running Video Devil. Reason: timestamp out of range for platform time_t"
I do have some working links ie Ah Me but at the start of the video selected, the video will be playing fine in the background, but a error pop up mid screen shows a "Remote Share, Could not connect to network server" which clears when "OK" is clicked and then the video continues to play with no issues. Its on all working videos, even if in the same site, for each new video, I will get this errors.
I will post a log when I can. Not a big deal but just wondering if there is an easy fix."
I have an atv1 with xbmc 13.2 and installed video devil...when i click on pornhub or on empflix i get the same errormessage :"Error running Video Devil. Reason: timestamp out of range for platform time_t"
but on my windows pc i dont get this errormessage. i dont know why its happening so please help me. i dont find anything on google.
Sorry, kind of new to this, so please forgive me if it's a dumb question, but where would one file an issue with the adultdvdempire movie scraper? It seems that AdultDVDEmpire changed their format. Where boxcovers used to be, there are now previews. I suck with regexp, and more importantly, the time I tried my zip file wasn't recognized as a supported format.
Can please update plugins?
Fantasti.cc not working, login does not work. Files does not play, even the images are displayed.
Kind regards
Fantasti.cc is not working for me also. It opens but there is no videos. Just shows "next page" but nothing inside them.
(2015-03-11, 15:39)lejer Wrote: [ -> ]Can please update plugins?
Kind regards
Issues can be posted at the gitshub page. Maybe someone will fix them then.
https://github.com/xbmc-adult/xbmc-adult
Ero-Tik (XXX) > Script Fail! > Repo > adultxbmc.com add-on repository
The next add-on, which is Erotik(XXX), that repo also give Script Fail error, am not sure which kind of specific repo that is in, but i have downloaded it from superrepo, as a metapackage zip.
I been getting the error for 4 days now, still is, the add-ons are updating, but script error when attempting to play a video. Before this problem, they been a lot of lagging (buffering), then it just give script error message...
the same for me for some days now:
also for this:
beeg (XXX) > Script Fail!
What are the latest/newest repositories? Is there one that include stuff from PinkLabel TV?
(2015-03-12, 00:07)dr.joaomarcelo Wrote: [ -> ]Fantasti.cc is not working for me also. It opens but there is no videos. Just shows "next page" but nothing inside them.
Fixed
Which is the master repository I should be using to get everything, or do I need to manually choose? Also, is there a way to add, queerporntube and other alt tubes??
(2015-03-17, 01:28)CoolKeith Wrote: [ -> ]Which is the master repository I should be using to get everything, or do I need to manually choose? Also, is there a way to add, queerporntube and other alt tubes??
See the first post in this thread for details
Any chance of getting these great 2 plug ins fixed?
Ero-Tik (XXX)
beeg (XXX)
Both get a Script Fail!
Thanks Smile
I add this, but nothing shows up in my video section is there something I am doing wrong?
Ero-Tik and Beeg my two favs are giving script error Sad
Ero-Tik and Beeg are not from this repo
