(2016-01-08, 12:58)mortael Wrote: [ -> ] (2016-01-08, 10:29)Yurikaze Wrote: [ -> ]Hi all,
I've searching through many forums for answers but still unable to come out with a conclusion.
Using latest Kodi 15.2 on windows, Playback in Erotik and whitecream is fine. Can see it's HD format. Trouble comes when want to skip to the good parts aka fast forward and it will drop the connection back to menu.
For other addons ie genesis or 1channel, the connection will stay and playback from the skip stepped portion, why not for xxx?
Anyone can advice?
That is because of the videohost Videomega. Since Kodi 15 and up there are problems skipping the videos from Videomega. Try XBMC 13 or Kodi 14 (it works for me) if it really bothers you....or try another host, like Openload
Can advise how to switch host to openload?
Xhamster is not working
(2015-10-31, 02:27)hansolo77 Wrote: [ -> ]The only available options in the settings are AUTO, DVDPlayer, and MPlayer. None of those work in Jarvis. Milhouse is building his versions based entirely on VideoPlayer. I asked if it would be possible to add in a DVDPlayer module of some sort, but he said this is a fundamental program built into Jarvis code and there is no way to change it when compiling. It's cool. Until the VideoDevil addon is updated to use VideoPlayer, I've just reverted to Isengard. Seems less buggy anyway.
If you want to test, try this test build
https://github.com/xbmc-adult/xbmc-adult....7.123.zip , if you could report back that would be great
(2016-01-10, 07:17)dquaid Wrote: [ -> ] (2015-10-31, 02:27)hansolo77 Wrote: [ -> ]The only available options in the settings are AUTO, DVDPlayer, and MPlayer. None of those work in Jarvis. Milhouse is building his versions based entirely on VideoPlayer. I asked if it would be possible to add in a DVDPlayer module of some sort, but he said this is a fundamental program built into Jarvis code and there is no way to change it when compiling. It's cool. Until the VideoDevil addon is updated to use VideoPlayer, I've just reverted to Isengard. Seems less buggy anyway.
If you want to test, try this test build https://github.com/xbmc-adult/xbmc-adult....7.123.zip , if you could report back that would be great
haha i just tried installing this today and got that error. came here and you just posted this yesterday, crazy timing, unfortunately it didnt work for me. i tried auto and the jarvis video setting. neither worked. im on milhouse #1226
(2016-01-12, 05:03)andypiznti Wrote: [ -> ] (2016-01-10, 07:17)dquaid Wrote: [ -> ] (2015-10-31, 02:27)hansolo77 Wrote: [ -> ]The only available options in the settings are AUTO, DVDPlayer, and MPlayer. None of those work in Jarvis. Milhouse is building his versions based entirely on VideoPlayer. I asked if it would be possible to add in a DVDPlayer module of some sort, but he said this is a fundamental program built into Jarvis code and there is no way to change it when compiling. It's cool. Until the VideoDevil addon is updated to use VideoPlayer, I've just reverted to Isengard. Seems less buggy anyway.
What did the logs say?
Anyway I am tracking this in github
Hi, thanks for this fantastic addon,
could you please update xhamster since "categories" section is not working and same to xvideos, categories is not working and next page has dissapeared.
I take a look to xhamster.com.cfg, but I was even unable to identify what code is being used to configure. ¿Can someone tell me what code is? I'm really interested in learning how this addon is coded.
thanks in advance
Hey guys,
Same as the previous poster's request. Xhamster categories section is not working. Thanks a lot for the great work guys.
(2016-01-19, 17:58)guyexotico Wrote: [ -> ]Hey guys,
Fixed but we end up with XXCat in front of each category name
Is there any addon with a good source for Playboy tv? UWC has it but it cuts out after a few seconds. Thanks
Hi Guys,
is there a version of the add-on that works with Kodi 16 ?
I did download the version from github but if i try to install it on Kodi 16 i get a error.
Structure wrong !
Thanks for your help
cu
MD
I haven't updated to Kodi 16 yet because I was afraid something like this would happen. I posted an inquiry about it MONTHS ago (see
here) but it was just kinda ignored. Not even a "we'll look into it". Kodi 16 uses a new video player, and this addon specifically shows in the logs that it sends the commands to a completely different one. The addon needs updated to work with Kodi 16, and unless the author(s) even acknowledge that, the community is at a loss.
(2016-03-14, 15:15)MovieDick Wrote: [ -> ]Hi Guys,
Structure wrong !
cu
MD
Could it be that you downloaded the sourcecode from github? Did you push the "download zip" on github page?
Try again with the Repo from the first page here in the forum..
https://github.com/xbmc-adult/xbmc-adult...-1.0.6.zip
AND...as i know, mrdougquaid already fixed the problem with the Jarvis Videoplayer in a earlier release.
Cheers,
Vashiel
Eporner and girlfriendvideos not work on jarvis. Fix on the way?
Ciao
(2016-03-26, 21:20)amused Wrote: [ -> ]Eporner and girlfriendvideos not work on jarvis. Fix on the way?
Ciao
eporner fixed same for gfvideos and motherless galleries
Where can we find girlfriendvideos Kodi addon?
