2014-04-25, 02:54
(2014-04-25, 02:42)mizifih Wrote: [ -> ]Jesus, good bye. Thank all those who tried and helped. Unsigning this thing.
Just install the provided zip file, the problem with the adult frodo repo has been solved.
(2014-04-25, 02:54)hstegeman Wrote: [ -> ](2014-04-25, 02:42)mizifih Wrote: [ -> ]Jesus, good bye. Thank all those who tried and helped. Unsigning this thing.
(2014-04-25, 02:58)mizifih Wrote: [ -> ](2014-04-25, 02:54)hstegeman Wrote: [ -> ](2014-04-25, 02:42)mizifih Wrote: [ -> ]Jesus, good bye. Thank all those who tried and helped. Unsigning this thing.
Yeah, I saw the file, I actually commented right after he posted. Thanks for the heads up
(2014-04-25, 03:13)hstegeman Wrote: [ -> ](2014-04-25, 02:58)mizifih Wrote: [ -> ](2014-04-25, 02:54)hstegeman Wrote: [ -> ]Just install the provided zip file, the problem with the adult frodo repo has been solved.
I did post it, that's why I did respond. I don't know what you mean with he.
(2014-04-25, 01:34)hstegeman Wrote: [ -> ](2014-04-18, 10:09)henrava Wrote: [ -> ]I have changed addon.xml from 1.0.5 zip file.
This is my modified addon.xml: (just replace the content of addon.xml with this)
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<addon id="repository.xbmcadult" name="XBMC-Adult repository" version="1.0.5" provider-name="xbmc-adult">
<extension point="xbmc.addon.repository" name="XBMC Adult repository">
<info compressed="false">http://raw.github.com/xbmc-adult/xbmc-adult/ghmaster/addons.xml</info>
<checksum>http://raw.github.com/xbmc-adult/xbmc-adult/ghmaster/addons.xml.md5</checksum>
<datadir zip="true">http://raw.github.com/xbmc-adult/xbmc-adult/raw/ghmaster</datadir>
</extension>
<extension point="xbmc.addon.metadata">
<summary>XBMC Addons for Adults Only</summary>
<description>This repository contains addons that are for adults only.</description>
<disclaimer></disclaimer>
<platform>all</platform>
</extension>
</addon>
Thank you very much, the repo is working again.
Edit:
The repo did seam to work, but it doesn't install any Addon.
Edit:
No problem with the repo, I did try to install addons from my adult profile, after going back to my master user profile everything is working without problems.
See for my version of the repo the next link.
https://www.dropbox.com/sh/1xepgqh2nw2ha...-1.0.5.zip
(2014-04-25, 03:42)mizifih Wrote: [ -> ](2014-04-25, 01:34)hstegeman Wrote: [ -> ](2014-04-18, 10:09)henrava Wrote: [ -> ]I have changed addon.xml from 1.0.5 zip file.
</extension>
</extension>
</addon>
Edit:
Edit:
Repo was recognized, but it tries to install the repo, say fantasti.cc, it shows the Downloading 0% status and then just stops, like canceling the download. I'm using XBMC 12.03 (19 DEC 2013), latest at the download page. Installed it like a week ago, on a clean windows installation.
(2014-04-25, 03:55)hstegeman Wrote: [ -> ](2014-04-25, 03:42)mizifih Wrote: [ -> ](2014-04-25, 01:34)hstegeman Wrote: [ -> ]Thank you very much, the repo is working again.
Edit:
Edit:
I did have problems installing addons too, you can read it in a previous post.
After closing xbmc 12.3 and restarting it in the master user profile it was working for me.
Edit:
I am making use of windows 8.1 on a lenovo q190. In my opinion windows should work.
<?xml version="1.0" encoding="UTF-8" standalone="true"?>
-<addon provider-name="xbmc-adult" version="1.0.5" name="XBMC-Adult repository" id="repository.xbmcadult">
-<extension name="XBMC Adult repository" point="xbmc.addon.repository">
</extension>
-<extension point="xbmc.addon.metadata">
<disclaimer/>
</extension>
</addon>
(2014-04-25, 04:15)mizifih Wrote: [ -> ](2014-04-25, 03:55)hstegeman Wrote: [ -> ](2014-04-25, 03:42)mizifih Wrote: [ -> ]Repo was recognized, but it tries to install the repo, say fantasti.cc, it shows the Downloading 0% status and then just stops, like canceling the download. I'm using XBMC 12.03 (19 DEC 2013), latest at the download page. Installed it like a week ago, on a clean windows installation.
Edit:
Master profile, I only have one profile, that I assume to be the Master one you are talking about ;(
EDIT:
yeah, checked, it's the master profile, the only one I have.
IE show me this for the XML file:
Code:<?xml version="1.0" encoding="UTF-8" standalone="true"?>
</extension>
<disclaimer/>
</extension>
</addon>
(2014-04-25, 04:28)hstegeman Wrote: [ -> ](2014-04-25, 04:15)mizifih Wrote: [ -> ](2014-04-25, 03:55)hstegeman Wrote: [ -> ]I did have problems installing addons too, you can read it in a previous post.
Edit:
EDIT:
</extension>
<disclaimer/>
</extension>
</addon>
Perhaps a log file can help to solve your problem.
(2014-04-25, 04:36)mizifih Wrote: [ -> ](2014-04-25, 04:28)hstegeman Wrote: [ -> ](2014-04-25, 04:15)mizifih Wrote: [ -> ]Master profile, I only have one profile, that I assume to be the Master one you are talking about ;(
EDIT:
</extension>
<disclaimer/>
</extension>
</addon>
This log ok?
http://xbmclogs.com/show.php?id=185276
(2014-04-25, 11:52)hstegeman Wrote: [ -> ](2014-04-25, 04:36)mizifih Wrote: [ -> ](2014-04-25, 04:28)hstegeman Wrote: [ -> ]Perhaps a log file can help to solve your problem.
This log ok?
Did you try to install an adult addon while you were making this xbmc log file? This should provide an error, I don't see any errors in your log file.
(2014-04-25, 02:26)nickr Wrote: [ -> ]The post 1 link works on Gotham. You are very demanding. People owe you nothing nada zip.And you have over 6000 posts here for what?? this forum is for getting info and to HELP people is it not...?? if you can't add any usefull info or HELP anyone I would just Shut Up...... it seems like you just like to "argue" with everyone.....
