2014-07-17, 02:30
2014-08-09, 19:12
(2014-07-17, 02:30)Warner306 Wrote: [ -> ]Thumbnails for FreeHDPorn are no longer working.
freehdporn.ws.cfg:
Change line under Videos
# Videos
item_info_build=http://freehdporn.ws%s
to
# Videos
item_info_build=%s
That should do the trick
2014-08-25, 02:27
(2014-05-21, 13:44)ismadder Wrote: [ -> ]Hi Dquaid,
I am Getting Errors on the VideoDevil on the following
Empflix & Pornhub = "Timestamp out of Range for plaform time_t"
I am receiving the same error on the same Empflix & Pornhub. Did anyone figure out what causes this? I am running XBMC on an ATV2 with Gotham 13.2
2014-09-15, 20:27
is there a way to fix the "Eporner" link? it hasn't been working for some time now. good site it is all in HD. Thanks in Advance.....
2014-09-25, 17:06
(2014-09-15, 20:27)strike0408 Wrote: [ -> ]is there a way to fix the "Eporner" link? it hasn't been working for some time now. good site it is all in HD. Thanks in Advance.....
I already fixed those. If you know how, you can get those fixes from my github and update your xbmc manually
https://github.com/Vashiel/xbmc-adult
2014-09-27, 11:17
Vashiel, make a pull request so it's reviewed in main github
2014-09-27, 14:08
(2014-09-27, 11:17)Mafarricos Wrote: [ -> ]Vashiel, make a pull request so it's reviewed in main github
Already did a week ago.
https://github.com/xbmc-adult/xbmc-adult...23/commits
2014-09-28, 19:03
2014-09-28, 20:09
2014-10-01, 09:33
None of my adult add-ons are working. I am on Kodi 13.2. Installed it fresh start last night but found the addons are there but when I access nothing. I am in the uk using virgin broadband. When I used xbmc gotham 13.1 everything was fine.
2014-10-08, 00:49
(2014-09-27, 14:08)vashiel Wrote: [ -> ](2014-09-27, 11:17)Mafarricos Wrote: [ -> ]Vashiel, make a pull request so it's reviewed in main github
I had a look,
- not all the fixes worked
- the fixes were mixed with new features, please keep fixes separated from new features (e.g. changes in layout, sorting etc)
I cherry-picked the ones that worked easily and left the ones that didn't work or were only partial fixes
2014-12-15, 19:27
Hi to all. I don't now who is original developer of xbmc-adult Tube8.
I have made some changes since only one of listitems was working "Top rated". I fixed regx and now every thing is working.
Also i have copy tube8 and made changes to work for Pornhub and now i have two add-ons for Tube8 and new for PornHub
Did i can to post this files to you so you can see it or put in some repo.
2014-12-15, 19:32
(2014-12-15, 19:27)mikimac Wrote: [ -> ]Hi to all. I don't now who is original developer of xbmc-adult Tube8.
I think it's here
2014-12-16, 00:54
(2014-12-15, 19:27)mikimac Wrote: [ -> ]Hi to all. I don't now who is original developer of xbmc-adult Tube8.Pornhub is already in videodevil
First read https://github.com/xbmc-adult/xbmc-adult...ntributors
Send a pull request for tube8 without the pornhub bits at https://github.com/xbmc-adult/xbmc-adult
2014-12-16, 02:03
I have send pull request for Tube8.
I know that pornhub is already in videodevil which i must say is an excellent addon.
In videodevil there isn't Next Page for pornhub.
This addon what i have made is copy from tube8 and have more views to choose for example:
Search, Categories and
Thanks again
mikimac
- Recently Featured
- Most Viewed Daily
- Most Viewed Weekly
- Most Viewed Mounthly
- Most Viewed All Time
- Top Rated Daily
- Top Rated Weekly
- Top Rated Mounthly
- Top Rated All Time
- Hottest
- Longest
- Newest
Thanks again
mikimac
