2014-03-13, 15:44
Hello I installed XBMC from the Nightlies\android\arm folder yesterday and I used the one dated Mar 7th. I then installed the Add-on ICEFILMS and I'm able to navigate to what I want but when I play a video all I get is a green screen but the audio sounds good..
Should I try installing the new March 13th file or is there another issue that I need to address.. My Cell is a Verizon LG G2..
Also if I need to install an older version do I just download and then rerun the install or do I need to remove the app first..
Thanks for your help...Scott
