Had the system working with a GT 210 card.
I just replaced the card with GT 610 card. Should be no problem.
Now there is no sound. Can't figure it out.
Any ideas
Sorry, XBMCbuntu Frodo with Nvidia drivers.
As I mentioned previously, the GT 210 card worked fine. The only issue was that I had to go into Alsamixer and unmute the volume controls on the Nvidia card.
I shut the system down, changed the card, rebooted.
I've also tried
sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
sudo apt-get update
sudo apt-get dist-upgrade
The video portion works fine, but alsa mixer doesn't seem to recognize the new card. It's just seeing the onboard Intel audio.
