Full Version: Looking for mini ITX case with rised PCI slot
Hey there,
i'm looking for a small mini ITX case where i can fit a ASUS Xonar Essence STX Soundcard. Prefered in a rised position to save space. Any suggestions?
Thanks in advance!
greetings iMap
(2014-03-14, 11:45)iMap Wrote: [ -> ]ASUS Xonar Essence STX Soundcard
Why do you need soundcard?
While not the smallest mini-ITX case, the Casetronic Travla C137 Mini-ITX case does have a raised PCI slot and even comes with the risers. I've used this case from some HTPC DVR builds and it's great. It's about the size of a blu-ray player.
(2014-03-14, 16:37)bluray Wrote: [ -> ]
- 600Ohm Headphones.
(2014-03-14, 21:28)Dougie Fresh Wrote: [ -> ]While not the smallest mini-ITX case, the Casetronic Travla C137 Mini-ITX case does have a raised PCI slot and even comes with the risers. I've used this case from some HTPC DVR builds and it's great. It's about the size of a blu-ray player.
Thanks! Nod
(2014-03-17, 11:08)iMap Wrote: [ -> ]
These "FiiO E6 Portable Headphone Amplifier, ASUS Xonar U3 Sound Cards, etc" might be easier and cheaper solution...
My friend said he enjoys using it with his gaming headphone....
