2015-04-27, 21:02
(2015-04-27, 06:38)leetwanker Wrote: [ -> ][code]Bus 001 Device 005: ID 0c16:0002 Gyration, Inc. RF Technology Receiver
[code]
I know my remote can be used with lirc,
Lirc is IR your receiver says its RF
[code]
(2015-04-27, 21:02)FishOil Wrote: [ -> ](2015-04-27, 06:38)leetwanker Wrote: [ -> ][code]Bus 001 Device 005: ID 0c16:0002 Gyration, Inc. RF Technology Receiver
[code]
(2015-04-27, 21:07)leetwanker Wrote: [ -> ](2015-04-27, 21:02)FishOil Wrote: [ -> ](2015-04-27, 06:38)leetwanker Wrote: [ -> ][code]Bus 001 Device 005: ID 0c16:0002 Gyration, Inc. RF Technology Receiver
[code]
Is there a different program that handles RF remotes? I've seen people use lirc to configure my remote. link
In fact, I've done it myself. I've just never had problems like the ones in my post.
(2015-04-27, 21:17)FishOil Wrote: [ -> ](2015-04-27, 21:07)leetwanker Wrote: [ -> ](2015-04-27, 21:02)FishOil Wrote: [ -> ]Lirc is IR your receiver says its RF
Sorry, I cant help you with that.
Everything I deal with is IR.
Lirc is pretty easy and straight forward with the correct receiver and just about ANY IR remote.
IMO there are far better remotes then the one you have.
Is there some reason you want this particular remote receiver combination?
(2015-04-28, 01:37)nickr Wrote: [ -> ]An RF remote will usually just emulate a keyboard, which is simple to work with.
Open a terminal and press some buttons. Are characters printed?
(2015-04-28, 02:02)nickr Wrote: [ -> ]Hey is this any use to you?
https://www.mythtv.org/wiki/Gyration-based_MCE_Remotes
(2015-04-28, 03:20)nickr Wrote: [ -> ]Actually I am floundering a bit as I don't know ALL the ins and outs, but this article http://nucblog.net/2014/01/mapping-the-b...e-control/ is pretty good at setting up a remote on openelec.
If the remote supports hid and creates an input device, i would think it should work with LIRC via devinput. However that is dependent of course on that remote device being supported in openelec.
Anyway, that article is the bees knees IMHO.
Kodi:~ # ps aux|grep lirc
213 root 0:00 /usr/sbin/eventlircd -f --evmap=/etc/eventlircd.d --socket=/run/lirc/lircd --release=_UP
476 root 0:07 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
580 root 0:00 grep lirc
Kodi:~ # killall -HUP lircd
killall: lircd: no process killed
