Full Version: Video files with multiple audio tracks and advanced settings.xml
So I'm trying to get this code to work in the advancedsettings.xml file because I have many video files with multiple audio tracks, specifically commentaries. When set to 'true', a window is supposed to popup the audio channel selection if there is more then one audio stream. However, nothing happens.
<tuxbox>
<audiochannelselection>true</audiochannelselection>
</tuxbox>
Any help is appreciated.
Can you file a bug report for this on http://trac.xbmc.org ? It's probably something that won't get much attention right away, as I'm not sure how active tuxbox-related issues are, and that way we can keep better track of it.
That is, I'm assuming this is just a tuxbox-specific feature?
(2014-03-17, 00:00)Ned Scott Wrote: [ -> ]Can you file a bug report for this on http://trac.xbmc.org ? It's probably something that won't get much attention right away, as I'm not sure how active tuxbox-related issues are, and that way we can keep better track of it.
No idea.
