(2014-03-17, 00:45)derrickrozay Wrote: [ -> ]Pi isnt really that cheap
$35 for the Pi
$10 for the case
$10 for the sd card
$10 for wifi
$5 for a charger
$15-$25 for a USB hub
$10 for a USB stick otherwise its too slow
Thats w/o shipping it ended up costing me around $120 now i'm looking to upgrade. I'm looking at a couple of options
The MyGica ATV1200
https://www.youtube.com/watch?v=uCC-m3s2y3s
or http://www.hardkernel.com/main/main.php
but I'll most likely end up waiting for the new quad cores dropping this month
It's cheap if you do it right. Calling the Raspberry Pi "expensive" or saying the parts will go above $100 is a pet peeve for me.
• $35 for the Pi, bought with other people so I got free shipping, which probably isn't an option for most people, but you never know :)
• no case. It's behind the TV. If I need a case then I probably have some legos or a small plastic box somewhere. The Pi actually fits nicely into a 50¢ electrical box from the hardware store.
• $5 for 8GB SD card, easy. You can get that price in a lot of local shops, so no shipping. We've also learned that some of the class 6 or 8 cards are actually faster than the class 10 cards when it comes to short reads and writes, which is more important for XBMC, so the most expensive SD card isn't always the best.
• $5 for a power supply sounds about right. meritline.com has them all the time for about that price, and they're typically not as crappy as stuff you get from DX.com. Plus, free shipping.
• Why a hub when you've only listed two USB devices total, one of which is optional (USB flash drive)? On my Pi's I typically use cheap USB hubs that are under $5, but one really isn't needed for XBMC use. Plus, if you buy a $30 hub then there's a good chance you can just power the Pi from that, and thus you won't need a power supply.
• Using a USB stick is the best way to get the fastest speeds on the Pi, but it's far from required thanks to the speed tweaks in XBMC v13 and the OpenELEC test builds. It was pretty slow before, but it has drastically improved.
• Even if I paid $300 for my HTPC I would still want it wired, but sure, throw $10 on for wifi. I like buying Airlink 101 wifi usb dongles from meritline.com when they go on sale for $10, with free shipping. Sometimes they even have multi antenna ones for $15.
It's easily in the $50-60 range (with shipping) for people who don't already have a spare SD card or USB power supply of some kind, and they often do. Even if you do have to buy those parts, those are parts that are easily reusable for other things, so there's little risk in trying the Pi.
Not saying that the ATV1200 is bad, and I will say that Hard Kernel's stuff is awesome, but like I said, it's a pet peeve of mine when someone calls the Raspberry Pi expensive.
