2014-03-17, 04:20
What is the best cheap ($200 or less) box that can actually take a 2.5" or 3.5" hard drive?
The only option I've seen so far aside from building something from scratch is the newest, impossible to locate, Intel NUC, and thats pushing past $200.
I've toyed with the idea of an external HDD on a Pi, but that didn't work without a bulky one with external power or a seperate USB hub, and the Pi is a bit slow.
I also see soooooo many different ARM/Android setups like the Cubox, TLBB, etc. But none of the ones I've seen have any support for a SATA 2.5" hard drive inside. This will end up attached to a TV with no internet access whatsoever, so networked streaming is out of the question. The goal is basically to fill an entire ~500MB to ~1TB drive with content, update it somewhere WITH wifi occasionally, and then let it do its thing.
Any help would be really appreciated. I've been hunting around and could use some.
