Full Version: Scripts on actions instead of keystrokes
Instead of using scripts on keystrokes I would like to go one level deeper and using scripts on actions.
Is there a way to use scripts on actions?
I got the idea that appcommand.xml would be acting on this level the same way keyboard.xml/remote.xml work. I cannot find a way to get it to work however.
Scripts on keystrokes are ok, but do not work when a virtual remote is used. They work on action level AFAIK. That's why I would like to find out how to use actions as an input.
Any help or direction very welcome! :-)
Thx in advance.
Scores
