Full Version: How to compile vdr + vnsiserver from source
Pages: 1 2 3 4 5
I have removed it. Still not working
syslog -> http://paste.ubuntu.com/13508369/
runvdr -> http://paste.ubuntu.com/13508378/
Its must have been my channels.conf or settings
1st log had this issue so I remove the use of picons - > http://xbmclogs.com/pedtzxejw
AddOnLog: VDR VNSI Client: Logged in at '1448494497+0' to 'VDR-Network-Streaming-Interface (VNSI) Server' Version: '1.3.1' with protocol version '8'
23:34:57 T:140081155270400   ERROR: SQL: Abort due to constraint violation
                                            Query: INSERT INTO channels (iUniqueId, bIsRadio, bIsHidden, bIsUserSetIcon, bIsUserSetName, bIsLocked, sIconPath, sChannelName, bIsVirtual, bEPGEnabled, sEPGScraper, iLastWatched, iClientId, idEpg) VALUES (53483305, 1, 0, 0, 0, 0, '/storage/downloads/hd.transparent-black_2014-09-02--00-00-01/tv/1_0_2_258D_7FB_2_11A0000_0_0_0.png', 'RTE R na G', 0, 1, 'client', 0, 16428, -1)
23:34:57 T:140081155270400   ERROR: CommitInsertQueries - failed to execute queries
23:34:57 T:140081155270400   ERROR: PVR - Load - failed to load channel groups
2nd log then had channel group erros, so I removed that setting -> http://xbmclogs.com/ppuc3oh7m
working fine now, well without picons, they used to work so I will continue to fiddle
I am also stuck at this ...
i cloned Jarvis, built, installed
i cloned platform, make , make install
i cloned kodi-platform, cmake, make , make install:
i fail on pvr cmake....
root@wheezy:/nas/kodi# git clone https://github.com/Pulse-Eight/platform.git platform-master
root@wheezy:/nas/kodi# cd platform-master/
root@wheezy:/nas/kodi/platform-master# cmake -DCMAKE_INSTALL_PREFIX=/usr/local
-- Configuring done
-- Generating done
-- Build files have been written to: /nas/kodi/platform-master
root@wheezy:/nas/kodi/platform-master# make clean
root@wheezy:/nas/kodi/platform-master# make && make install
[100%] Building CXX object CMakeFiles/p8-platform.dir/src/util/StringUtils.cpp.o
Linking CXX static library libp8-platform.a
[100%] Built target p8-platform
Install the project...
-- Install configuration: ""
-- Installing: /usr/local/lib/libp8-platform.a
-- Up-to-date: /usr/local/include/p8-platform/os.h
-- Up-to-date: /usr/local/include/p8-platform/posix/os-socket.h
-- Up-to-date: /usr/local/include/p8-platform/posix/os-threads.h
-- Up-to-date: /usr/local/include/p8-platform/posix/os-types.h
-- Up-to-date: /usr/local/include/p8-platform/sockets/cdevsocket.h
-- Up-to-date: /usr/local/include/p8-platform/sockets/socket.h
-- Up-to-date: /usr/local/include/p8-platform/sockets/tcp.h
-- Up-to-date: /usr/local/include/p8-platform/threads/atomics.h
-- Up-to-date: /usr/local/include/p8-platform/threads/mutex.h
-- Up-to-date: /usr/local/include/p8-platform/threads/threads.h
-- Up-to-date: /usr/local/include/p8-platform/util/atomic.h
-- Up-to-date: /usr/local/include/p8-platform/util/buffer.h
-- Up-to-date: /usr/local/include/p8-platform/util/StringUtils.h
-- Up-to-date: /usr/local/include/p8-platform/util/StdString.h
-- Up-to-date: /usr/local/include/p8-platform/util/timeutils.h
-- Up-to-date: /usr/local/include/p8-platform/util/util.h
-- Up-to-date: /usr/local/lib/pkgconfig/p8-platform.pc
-- Up-to-date: /usr/local/lib/p8-platform/p8-platform-config.cmake
Cloned and installed kodi-platform
root@wheezy:/nas/kodi# git clone https://github.com/xbmc/kodi-platform.git
root@wheezy:/nas/kodi# cd kodi-platform/
root@wheezy:/nas/kodi/kodi-platform# cmake -DCMAKE_INSTALL_PREFIX=/usr/local
-- Configuring done
-- Generating done
-- Build files have been written to: /nas/kodi/kodi-platform
root@wheezy:/nas/kodi/kodi-platform# make clean && make && make install
[100%] Building CXX object CMakeFiles/kodiplatform.dir/src/util/XMLUtils.cpp.o
Linking CXX shared library libkodiplatform.so
[100%] Built target kodiplatform
-- Installing: /usr/local/lib/libkodiplatform.so.16.0.0
-- Up-to-date: /usr/local/lib/libkodiplatform.so.16.0
-- Up-to-date: /usr/local/include/kodi/util/XMLUtils.h
-- Up-to-date: /usr/local/lib/pkgconfig/kodiplatform.pc
-- Up-to-date: /usr/local/lib/kodiplatform/kodiplatform-config.cmake
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
and now pvr....:
root@wheezy:/nas/kodi/kodi-platform# cd ..
root@wheezy:/nas/kodi# cd Jarvis/pvr.vdr.vnsi/
root@wheezy:/nas/kodi/Jarvis/pvr.vdr.vnsi# cmake -DCMAKE_INSTALL_PREFIX=/usr/local
CMake Error at CMakeLists.txt:11 (find_package):
  By not providing "Findplatform.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "platform",
  but CMake did not find one.
  Could not find a package configuration file provided by "platform" with any
  of the following names:
    platformConfig.cmake
  Add the installation prefix of "platform" to CMAKE_PREFIX_PATH or set
  "platform_DIR" to a directory containing one of the above files.  If
  "platform" provides a separate development package or SDK, be sure it has
  been installed.
-- Configuring incomplete, errors occurred!
See also "/nas/kodi/Jarvis/pvr.vdr.vnsi/CMakeFiles/CMakeOutput.log".
I guess you are in the wrong thread. This thread is about compiling vdr and vdr-plugin-vnsiserver
Thanks for this guide but I am having issues getting things to work.
Firstly, whenever I use any of the commands that contain the ~ character I am always greeted with a no such file or directory error.
So I have simply left this out and navigated manually.
Then next area that gave me an issue was in step 7.
cp PLUGINS/src/vnsiserver/vnsiserver/allowed_hosts.conf /var/vdr/plugins/vnsiserver
This always returns a no such file or directory error.
So I found a copy of allowed_hosts.conf from another folder and copied it to the appropriate folder.
The command in step 8 also gave me the same error, so again I copied it from another location.
Step 10 confuses me as it says Autostart VDR but not sure if there should be a procedure to do this.
So as far as I can see, I have all the right things in place.
The only problem is that after a reboot I can't seem to be able to do anything to get TV channels on Kodi.
Reading through the thread I noticed that a user was asked to check whether sudo start vdr works, so I tried this but I just get a command not found error.
I've double checked all the configurations files are in the right place and have the correct information but am baffled as to what may be wrong or what I am doing that is wrong.
Quote:Step 10 confuses me as it says Autostart VDR but not sure if there should be a procedure to do this.
This step is outdated for newer versions of Ubuntu and other Linux distros. Upstart is dead and was superseded by systemd
Pages: 1 2 3 4 5
