Full Version: Ubuntu 14.04 automatic constant switching between buttons
Hi
I am using XBMC Nightly build from today (18-03-2014).
The last week or so XBMC has looked like this (see video). Constant switching between buttons.
Anyone have an idea what's wrong?
View My Video
disable the joystick via guisettings.xml
(2014-03-18, 14:39)fritsch Wrote: [ -> ]disable the joystick via guisettings.xml
Thank you very much it worked perfectly. Is this a bug in XBMC or Ubnuntu 14:04 do you think?
xbmc bug - i could not track that down last time I searched for it. So I ended disabling joystick by default. This won't help upgrading users of course.
If you find time, please head over to trac.xbmc.org and try to file it. xbmc debug log with the option enabled will be enough.
a Debug Log of the issue would be helpful too.
(2014-03-18, 15:41)fritsch Wrote: [ -> ]xbmc bug - i could not track that down last time I searched for it. So I ended disabling joystick by default. This won't help upgrading users of course.
Will do, so it does not happen to others.
