(2014-03-26, 07:02)abudabi Wrote: [ -> ]Is this a "no limitation" install of ubuntu? Meaning I can upgrade it later to the release version of Tahr with apt-get upgrade?
yes
wsnipex, can I remove the first iteration of this beta build from the mirrors or do you want to keep it around?
(2014-03-26, 00:42)uNiversal Wrote: [ -> ]no not until Trusty thar is released officially if you just want to upgrade xbmc then thers Team XBMC PPA (wiki) othewise release upgrades only work between older and final releases, thar is beta? or rc?
You can use do-release-upgrade to upgrade to pre-releases, from memory the argument is -d
(2014-03-26, 05:55)nickr Wrote: [ -> ]What was XBMCbuntu 12 based on? Was it 12.10 or something.
Doing an upgrade is probably going to have to go through the intermediate releases. Upgrades generally only go release-->release or LTS-->LTS.
You will likely experience breakage if you have to go through too many upgrades to get to thar. I would reinstall from scratch (backing up what you want to keep).
Ah yeah, I forgot about the upgrade path... 3 distro upgrades + a beta distro would probably set my pc on fire
Might give it a try though and report back, I dont really have anything to lose on that partition.
my advise: don't, just reinstall
@kib: yes, you can remove the old iso
No deal on upgrding - v12 doesnt come with update-manager and none of the default quantal repos are reachable. After manually installing update-manager-core, do-release-upgrade fails because it is unable to refreshe quantal's repos.
(2014-03-25, 22:13)uNiversal Wrote: [ -> ]Its news for me that you need any gnome/unity to vnc anywhere. But this isnt the right topic, so look at vnc realted threads here in forums or somewhere else.
Just in the interest of completeness. According to my research it seems like VNC with the later versions of gnome and unity will not work as they require 3D accelaration (even the supposed 2D ones)
http://askubuntu.com/questions/361617/do...s-in-13-10
Cheers and thanks for this awesome build!
How can I install advanced launcher on this version.
I want to check this out in order to be able to run xbmc and if need firefox or chrome.
I have a zotac id18 with celeron 1007u
wsnipex With final beta of tahr being released, will you be making a new image?
no, only when we change something xbmcbuntu related. just do normal upgrade procedure:
sudo apt-get update
sudo apt-get upgrade
Cool.. with all my vnc and desktop manager experimentation I want to do a clean install so just wanted to make sure there's not a new iso coming out soon.
Cheers!
Busy setting up the mysql shared database stuff. Am I right in saying that with this iso there is no XBMC user and xbmc runs as the user that you type in during the initial setup wizard?
Edit: Nevermind.. forgot the mysql user can be different from the linux user
How do I get to desktop in this version of Xbmcbuntu?
I installed it with username livingroom, however reading other threads they suggest I login as Xbmcbuntu or xbmc with blank password - can't seem to login using those credentials
1. Post:
Quote:Important
To switch to the desktop on the _live-session_(when you ran "Try XBMCbuntu"):
1) enter xbmc for username
2) click the wrench icon top right, choose xbmcbuntu
3) click login
