2014-03-18, 21:09
2014-03-18, 21:14
If I'm not mistaken that addon isn't in our repo
2014-03-18, 22:33
I figured out that its the T0mm0 module that is messed up. Its not being installed on XBMC.
Even when i try to install it manually through the repository.
Who can address this issue ? I noticed many plugins are dependent on this t0mm0 module -> t0mm0.common.addon ?
is it xbmc or is it the author we need to contact ?
Okay UPDATE: when i installed the plugin directly : http://ftp.heanet.ie/mirrors/xbmc/addons...-2.1.1.zip
it works fine.
its onyl when i try install the plugin through repository it does not work
it works fine.
2014-03-18, 22:38
I think the "common" bit means that it's shared between several t0mm0 addons. Looking at Google, all paths lead back to 1Channel, SportsDevil, IceFilms, and other similar addons that aren't supported on this site.
So, best guess at "who can address this issue" would be xbmchub.
2014-03-18, 23:00
oh sorry, i thought this was a module for XBMC and not classified as none supported module at XBMC.
