Full Version: MCE remote in XBMC
Hi
I got a MCE remote which I'd like to work with XBMC only.
Can I make the green button to load XBMC?
I've tried to install a addon and different Windows regedit files,
but allmost with no luck.
I really need an A-B-C guide.... Hope someone can help.
This is an older article and some of what's in it is likely no longer valid, but it where I found information on how to do what you want to do. There is a paragraph that begins with the line, "You will likely want to be able to launch XBMC using the remote." See if that helps you. Obviously you'd use KEY_GREEN where it mentions KEY_BLUE. The article is at:
http://tech.iprock.com/?p=1363
This site help me sort out my mce remote, including "make the green button load XBMC". Wink
http://xbmccustomregis.sourceforge.net/r...art_Button
Fantastic.. Cant wait to get home and try it.. Thanks
