2014-03-20, 05:44
2014-03-20, 06:25
Unfortunately ffmpeg, which xbmc uses to decode audio, does not support DSD or DFF, as far as I know.
2014-03-20, 20:22
not gonna help you much probably but funnai since i have independently worked on it in the last few days. i have a basic dff decoder add-on in my fork at https://https://github.com/notspiff/xbmc-cmake / https://https://github.com/notspiff/audiodecoder.dsd
so it's definitely doable.
2014-03-21, 17:08
ironic_monkey,
Can it be used by a user without any knowledge of coding? It is a simple addon or something more complex?
2014-03-21, 19:29
it's an add-on which only works with my fork since audio decoders aren't add-ons in upstream.
2014-03-21, 20:25
Hi ironic_monkey, I try compile, but have error
C:\xbmc-cmake-master\xbmc\visualizations\Milkdrop\Plugin.vcxproj : error : Project "C:\xbmc-cmake-master\xbmc\visualizations\Milkdrop\Plugin.vcxproj" could not be found.
C:\xbmc-cmake-master\xbmc\visualizations\DirectXSpectrum\directx_spectrum.vcxproj : error : Project "C:\xbmc-cmake-master\xbmc\visualizations\DirectXSpectrum\directx_spectrum.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\libmodplug\libmodplug_2010.vcxproj : error : Project "C:\xbmc-cmake-master\lib\libmodplug\libmodplug_2010.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\libRTV\libRTV.vcxproj : error : Project "C:\xbmc-cmake-master\lib\libRTV\libRTV.vcxproj" could not be found.
C:\xbmc-cmake-master\xbmc\visualizations\WaveForm\Waveform.vcxproj : error : Project "C:\xbmc-cmake-master\xbmc\visualizations\WaveForm\Waveform.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\stsound\StSoundLibrary\StSoundLibrary.vcxproj : error : Project "C:\xbmc-cmake-master\lib\stsound\StSoundLibrary\StSoundLibrary.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\libmad\msvc++\libmad.vcxproj : error : Project "C:\xbmc-cmake-master\lib\libmad\msvc++\libmad.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\vgmstream\win32\win32.vcxproj : error : Project "C:\xbmc-cmake-master\lib\vgmstream\win32\win32.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\nosefart\NoseFartXBMC.vcxproj : error : Project "C:\xbmc-cmake-master\lib\nosefart\NoseFartXBMC.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\libsidplay2\libsidplay\win\VC\libsidplay.vcxproj : error : Project "C:\xbmc-cmake-master\lib\libsidplay2\libsidplay\win\VC\libsidplay.vcxproj" could not be found.
C:\xbmc-cmake-master\lib\libhdhomerun\hdhomerun\hdhomerun.vcxproj : error : Project "C:\xbmc-cmake-master\lib\libhdhomerun\hdhomerun\hdhomerun.vcxproj" could not be found.
C:\xbmc-cmake-master\xbmc\visualizations\Vortex\Vortex\Vortex.vcxproj : error : Project "C:\xbmc-cmake-master\xbmc\visualizations\Vortex\Vortex\Vortex.vcxproj" could not be found.
2014-03-21, 20:35
my fork only builds on linux (using the project/cmake buildsystem)
2014-05-14, 19:49
Hum, seems ffmpeg support DSD (DSF files): https://ffmpeg.org/general.html
2014-05-14, 19:53
yes, that was added about 2 weeks ago. not in any released version as of yet afaik.
2014-12-03, 16:05
As dsf/dff file playback is supported now it would make sense to also support their scanning to the Kodi library.
