(2014-03-20, 20:40)illiac4 Wrote: [ -> ] (2014-03-20, 09:56)teeedubb Wrote: [ -> ]That log file may have been before I deleted it, it should be gone now. Still happens with 304 drivers
crashlog http://paste.ubuntu.com/7124064/
debug log, isnt from same instance as crashlog though : http://paste.ubuntu.com/7124070/
EDIT same thing with my laptop running kubuntu 14.04 x64 + alpha12, so its probably something with ubuntu
debug log http://paste.ubuntu.com/7124096/
crash log http://paste.ubuntu.com/7124099/
I'd say remove
18:18:17 T:140495178725120 NOTICE: Thread FileCache start, auto delete: false
18:18:17 T:140495178725120 INFO: CFileCache:rocess - Hit eof.
18:18:17 T:140495854479104 INFO: WakeOnLan - Magic packet send to 'F4:6D:04D:E3:FD'
18:18:17 T:140495178725120 DEBUG: Thread FileCache 140495178725120 terminating
18:18:17 T:140495170332416 DEBUG: CFileCache::Open - opening <bossanova808/repository.bossanova808/raw/master/staging/addons.xml.md5> using cache
18:18:17 T:140495170332416 DEBUG: CurlFile::Open(0x7fc7740aec70) http://github.com/bossanova808/repositor...ns.xml.md5
It looks like if the addon repository is not available (if the data can not be accessed or. get invalid request) then XBMC crashes, because all those addons repos are not available.. I think so, but could be wrong.
I saw that last night but Id had a few drinks before I turned on xbmc and didnt want to make things worse by tinkering when drunk hehe
Ive removed bossanova's repo and while xbmc stays open for longer, it still crashes - now on my repo
Something to do with GitHub I guess?
EDIT removed my repo and now xbmc is fine.
I did solve (partially) the restarting issue on my end. Here is what I did.
Using ssh, I went to ~/.xbmc/addons/ and started removing the repositories, one bye one. I would delete one, wait for it to crash and move to the next. I removed appx 8 repos. When I removed tOmmO's repository (can't remember where I got this repo, its possible it was from xunity or xbmchub), the crashing stopped. It seems to be stable now, but I haven't moved around in xbmc much yet. I will report back if I notice anything else.
EDIT: as soon as I click on the "sports-a-holic" addon, it crashes again. Sportsdevil seems to work fine.
(2014-03-20, 21:46)beschmid Wrote: [ -> ]EDIT: as soon as I click on the "sports-a-holic" addon, it crashes again. Sportsdevil seems to work fine.
you using the latest Repo of SportsDevil
or you using an older version?
----- maybe we should start a list... :/
you're right... the addon SportsDevil itself is not broken. I removed just the repo folder, and it works!!!
thanks @bechmid, for pointing me in the right direction.
I believe I was using maxmusterman's repo. But... I also used the Sportsdevil-Fixes addon to update Sportsdevil.
Edit: No I was not using Maxmusterman's repo. I don't have his repo installed on my system.
Do the offending repos use github?
Please, can you tell us what addon have you installed on your XBMC ?
Because I also experience these crashes so way should have at least one common buggy addon...
I have alot of addons installed, but removing two repositories that used github is what sorted the issue for me (bossanovas repo + mine). Check the last few lines of the xbmc
debug log (wiki) after a crash to see which addon/repo was last accessed by xbmc.
Personnally, I removed the following ones and my XBMC is now starting again :
- addons/repository.teeedubb
- addons/script.tv.show.next.aired
- addons/plugin.video.mangastv
- addons/script.steam.launcher
I'll try to reinstall them one by one later.
I removed:
repository.t0mm0
repository.smoothstreams
repository.mikey1234
repository.mash2k3
repository.Jas0npc
repository.istream
repository.googlecode.kozz-addons
repository.googlecode.anarchintosh-projects
repository.eleazar
repository.eldorado
repository.divingmule.addons
repository.Coolwave
OK. I am not alone
Started last night (March 19th) around midnight.
I pulled new nightly today but no change.
I do not run many repos.
Will try to remove some addons today to see if it helps.
http://pastebin.com/QmTt7Af8
(2014-03-20, 22:57)uomiarz Wrote: [ -> ]OK. I am not alone
hmmm... i don't see any addons. you might be suffering from some of the NVIDIA stuff from the first page of this thread.
(2014-03-20, 22:59)locomot1f Wrote: [ -> ] (2014-03-20, 22:57)uomiarz Wrote: [ -> ]OK. I am not alone
Would it run fine since BETA 1 for so many days and than last night started to crash?
Weird thing is all these posts here are from yesterday and today.
I will downgrade NVIDIA tonight.
