Full Version: xbmc crashes shortly after starting on my lenovo thinkpad os linux mint 16
Could use some help! I have uninstalled then reinstalled xbmc and mint trying to get xbmc working again. I am at a loss. I will attach a copy of crash log. Hopefully someone has had this problem and has a solution. I love this media center and this is the first time I have had a problem I couldn't work through.
thanks in advance for any and all help
Lorne
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri Mar 21 00:23:46 EDT 2014
XBMC Options:
Arch: i686
Kernel: Linux 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:12:00 UTC 2013
Release:
Distributor ID: LinuxMint
Description: Linux Mint 16 Petra
Release: 16
Codename: petra
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/lorne/core (2014-03-21 00:23:46.194302337 -0400)
[New LWP 3013]
[New LWP 3018]
[New LWP 2988]
[New LWP 2989]
[New LWP 2990]
[New LWP 2997]
[New LWP 3005]
[New LWP 3006]
[New LWP 3012]
[New LWP 2974]
[New LWP 3009]
[New LWP 3010]
[New LWP 3011]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0xb5962ae2 in gnutls_x509_crt_import () from /usr/lib/i386-linux-gnu/libgnutls.so.26
Thread 13 (Thread 0xa4cdfb40 (LWP 3011)):
#0 0xb774e424 in __kernel_vsyscall ()
#1 0xb5cb5f41 in select () from /lib/i386-linux-gnu/libc.so.6
#2 0x082de96b in JSONRPC::CTCPServer::Process() ()
#3 0x08da7195 in CThread::Action() ()
#4 0x08da782d in CThread::staticThread(void*) ()
#5 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#6 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
Thread 12 (Thread 0xa54e0b40 (LWP 3010)):
#2 0x082dc0d1 in SOCKETS::CSocketListener::Listen(int) ()
#3 0x082d22d0 in EVENTSERVER::CEventServer::Run() ()
#4 0x082d25d0 in EVENTSERVER::CEventServer::Process() ()
#5 0x08da7195 in CThread::Action() ()
#6 0x08da782d in CThread::staticThread(void*) ()
#7 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#8 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
Thread 11 (Thread 0xabcd5b40 (LWP 3009)):
#1 0xb6b6ac33 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib/i386-linux-gnu/libpthread.so.0
#2 0x08367076 in CJobManager::GetNextJob(CJobWorker const*) ()
#3 0x0836761b in CJobWorker::Process() ()
#4 0x08da7195 in CThread::Action() ()
#5 0x08da782d in CThread::staticThread(void*) ()
#6 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#7 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
Thread 10 (Thread 0xb500f700 (LWP 2974)):
#1 0xb5cb4d09 in ioctl () from /lib/i386-linux-gnu/libc.so.6
#2 0xb586f9e0 in drmIoctl () from /usr/lib/i386-linux-gnu/libdrm.so.2
#3 0xb4571dd2 in drm_intel_gem_bo_start_gtt_access () from /usr/lib/i386-linux-gnu/libdrm_intel.so.1
#4 0xb4571e73 in ?? () from /usr/lib/i386-linux-gnu/libdrm_intel.so.1
#5 0xb456c330 in drm_intel_bo_wait_rendering () from /usr/lib/i386-linux-gnu/libdrm_intel.so.1
#6 0xb391f030 in ?? () from /usr/lib/i386-linux-gnu/dri/i965_dri.so
#7 0xb3934325 in ?? () from /usr/lib/i386-linux-gnu/dri/i965_dri.so
#8 0xb3588d6f in _mesa_Clear () from /usr/lib/i386-linux-gnu/libdricore9.2.1.so.1
#9 0x08ccb43c in CRenderSystemGL::ClearBuffers(unsigned int) ()
#10 0x0854d3a7 in CGraphicContext::Clear(unsigned int) ()
#11 0x085f439e in CGUIWindow::ClearBackground() ()
#12 0x085fc7ec in CGUIWindowManager::RenderPass() ()
#13 0x085fc9e7 in CGUIWindowManager::Render() ()
#14 0x08b86f51 in CApplication::RenderNoPresent() ()
#15 0x08b88c6e in CApplication::Render() ()
#16 0x08c35048 in CXBApplicationEx::Run() ()
#17 0x08c3d917 in XBMC_Run ()
#18 0x082a83f3 in main ()
Thread 9 (Thread 0xa44deb40 (LWP 3012)):
#1 0xb5caea0b in poll () from /lib/i386-linux-gnu/libc.so.6
#2 0xb70ef819 in ?? () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#3 0xb70ef28c in avahi_simple_poll_run () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#4 0xb70ef4e8 in avahi_simple_poll_iterate () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#5 0xb70ef790 in avahi_simple_poll_loop () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
#6 0xb70ef884 in ?? () from /usr/lib/i386-linux-gnu/libavahi-common.so.3
Thread 8 (Thread 0xa7ccdb40 (LWP 3006)):
#2 0xb66c561e in ?? () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#3 0xb671fa19 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#4 0xb676f43b in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#5 0xb676f3ad in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#6 0xb676f3ad in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#7 0xb676ff04 in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#8 0xb6770073 in PyEval_EvalCode () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#9 0xb67aae75 in PyRun_FileExFlags () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#10 0x08c79bd4 in XBPyThread::Process() ()
#11 0x08da7195 in CThread::Action() ()
#12 0x08da782d in CThread::staticThread(void*) ()
#13 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#14 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
Thread 7 (Thread 0xa84ceb40 (LWP 3005)):
#1 0xb5c86766 in nanosleep () from /lib/i386-linux-gnu/libc.so.6
#2 0xb5cb699d in usleep () from /lib/i386-linux-gnu/libc.so.6
#3 0x082c0e45 in Sleep(unsigned int) ()
#4 0x08c5d9e2 in XBMCAddon::xbmc::sleep(long) ()
#5 0x08c833d7 in ?? ()
#6 0xb671fa39 in PyCFunction_Call () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#7 0xb676f43b in PyEval_EvalFrameEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#8 0xb676ff04 in PyEval_EvalCodeEx () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#9 0xb6770073 in PyEval_EvalCode () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#10 0xb67aae75 in PyRun_FileExFlags () from /usr/lib/i386-linux-gnu/libpython2.7.so.1.0
#11 0x08c79bd4 in XBPyThread::Process() ()
#12 0x08da7195 in CThread::Action() ()
#13 0x08da782d in CThread::staticThread(void*) ()
#14 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#15 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
Thread 6 (Thread 0xb45d7b40 (LWP 2997)):
#2 0x08da76e1 in CThread::Sleep(unsigned int) ()
#3 0x08b43f2f in MEDIA_DETECT::CDetectDVDMedia::Process() ()
Thread 5 (Thread 0xb43ffb40 (LWP 2990)):
#2 0x08a8e578 in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#3 0x08a8e650 in PERIPHERALS::CPeripheralBusUSB::Process() ()
Thread 4 (Thread 0xb4dd8b40 (LWP 2989)):
#2 0xb6110f47 in ?? () from /usr/lib/i386-linux-gnu/libasound.so.2
#3 0xb611111e in snd_pcm_wait () from /usr/lib/i386-linux-gnu/libasound.so.2
#4 0x08757000 in CAESinkALSA::AddPackets(unsigned char*, unsigned int, bool) ()
#5 0x0874c807 in CSoftAE::RunOutputStage(bool) ()
#6 0x08751438 in CSoftAE::Run() ()
#7 0x08da6408 in CThread::Process() ()
#8 0x08da7195 in CThread::Action() ()
#9 0x08da782d in CThread::staticThread(void*) ()
#10 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#11 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
Thread 3 (Thread 0xb100cb40 (LWP 2988)):
#2 0xb5849bbd in ?? () from /usr/lib/i386-linux-gnu/libpulse.so.0
#3 0xb58384fe in pa_mainloop_poll () from /usr/lib/i386-linux-gnu/libpulse.so.0
#4 0xb5838d2d in pa_mainloop_iterate () from /usr/lib/i386-linux-gnu/libpulse.so.0
#5 0xb5838e04 in pa_mainloop_run () from /usr/lib/i386-linux-gnu/libpulse.so.0
#6 0xb5849b5c in ?? () from /usr/lib/i386-linux-gnu/libpulse.so.0
#7 0xb56834bd in ?? () from /usr/lib/i386-linux-gnu/pulseaudio/libpulsecommon-4.0.so
#8 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#9 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
Thread 2 (Thread 0xa9cd1b40 (LWP 3018)):
#3 0x083255e8 in CAlarmClock::Process() ()
Thread 1 (Thread 0xa3cddb40 (LWP 3013)):
#1 0xb3b407fa in ?? () from /usr/lib/i386-linux-gnu/libcurl-gnutls.so.4
#2 0xb3b414f9 in ?? () from /usr/lib/i386-linux-gnu/libcurl-gnutls.so.4
#3 0xb3b42088 in ?? () from /usr/lib/i386-linux-gnu/libcurl-gnutls.so.4
#4 0xb3b18ccc in ?? () from /usr/lib/i386-linux-gnu/libcurl-gnutls.so.4
#5 0xb3b2b208 in ?? () from /usr/lib/i386-linux-gnu/libcurl-gnutls.so.4
#6 0xb3b3b852 in ?? () from /usr/lib/i386-linux-gnu/libcurl-gnutls.so.4
#7 0xb3b3c4d0 in curl_multi_perform () from /usr/lib/i386-linux-gnu/libcurl-gnutls.so.4
#8 0x0885df29 in XCURL::DllLibCurl::multi_perform(void*, int*) ()
#9 0x08845c26 in XFILE::CCurlFile::CReadState::FillBuffer(unsigned int) ()
#10 0x08846365 in XFILE::CCurlFile::CReadState::Connect(unsigned int) ()
#11 0x0884a27a in XFILE::CCurlFile::Open(CURL const&) ()
#12 0x0886085e in XFILE::CFile::Open(CStdStr<char> const&, unsigned int) ()
#13 0x088642ce in XFILE::CFileCache::Open(CURL const&) ()
#14 0x0886080c in XFILE::CFile::Open(CStdStr<char> const&, unsigned int) ()
#15 0x0871925b in ADDON::CRepository::FetchChecksum(CStdStr<char> const&) ()
#16 0x08719ab6 in ADDON::CRepository::Checksum() ()
#17 0x0871bc90 in ADDON::CRepositoryUpdateJob::GrabAddons(boost::shared_ptr<ADDON::CRepository>&) ()
#18 0x0871c3ff in ADDON::CRepositoryUpdateJob::DoWork() ()
#19 0x083675f0 in CJobWorker::Process() ()
#20 0x08da7195 in CThread::Action() ()
#21 0x08da782d in CThread::staticThread(void*) ()
#22 0xb6b66d78 in start_thread () from /lib/i386-linux-gnu/libpthread.so.0
#23 0xb5cbe01e in clone () from /lib/i386-linux-gnu/libc.so.6
############# END STACK TRACE ###############
################# LOG FILE ##################
00:23:34 T:3036739328 NOTICE: -----------------------------------------------------------------------
00:23:34 T:3036739328 NOTICE: Starting XBMC (12.0-RC3 Git:7a6cb7f), Platform: Linux (Linux Mint 16 Petra, 3.11.0-12-generic i686). Built on Sep 12 2013
00:23:34 T:3036739328 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
00:23:34 T:3036739328 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
00:23:34 T:3036739328 NOTICE: special://masterprofile/ is mapped to: /home/lorne/.xbmc/userdata
00:23:34 T:3036739328 NOTICE: special://home/ is mapped to: /home/lorne/.xbmc
00:23:34 T:3036739328 NOTICE: special://temp/ is mapped to: /home/lorne/.xbmc/temp
00:23:34 T:3036739328 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
00:23:34 T:3036739328 NOTICE: Local hostname: lorne-ThinkPad-R500
00:23:34 T:3036739328 NOTICE: Log File is located: /home/lorne/.xbmc/temp/xbmc.log
00:23:34 T:3036739328 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
00:23:34 T:3036739328 NOTICE: Enumerated ALSA devices:
00:23:34 T:3036739328 NOTICE: Device 1
00:23:34 T:3036739328 NOTICE: m_deviceName : default
00:23:34 T:3036739328 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
00:23:34 T:3036739328 NOTICE: m_displayNameExtra:
00:23:34 T:3036739328 NOTICE: m_deviceType : AE_DEVTYPE_PCM
00:23:34 T:3036739328 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
00:23:34 T:3036739328 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
00:23:34 T:3036739328 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
00:23:34 T:3036739328 NOTICE: Device 2
00:23:34 T:3036739328 NOTICE: m_deviceName : @:CARD=Intel,DEV=0
00:23:34 T:3036739328 NOTICE: m_displayName : HDA Intel
00:23:34 T:3036739328 NOTICE: m_displayNameExtra: CX20561 Analog
00:23:34 T:3036739328 NOTICE: m_sampleRates : 44100,48000,96000
00:23:34 T:3036739328 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
00:23:34 T:3036739328 NOTICE: Device 3
00:23:34 T:3036739328 NOTICE: m_deviceName : iec958:CARD=Intel,DEV=0
00:23:34 T:3036739328 NOTICE: m_displayNameExtra: CX20561 Digital S/PDIF
00:23:34 T:3036739328 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
00:23:34 T:3036739328 NOTICE: load settings...
00:23:34 T:3036739328 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:23:34 T:3036739328 NOTICE: loading special://masterprofile/guisettings.xml
00:23:34 T:3036739328 NOTICE: Getting hardware information now...
00:23:34 T:3036739328 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
00:23:34 T:3036739328 NOTICE: Loaded playercorefactory configuration
00:23:34 T:3036739328 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
00:23:34 T:3036739328 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
00:23:34 T:3036739328 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
00:23:34 T:3036739328 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
00:23:34 T:3036739328 NOTICE: Default DVD Player: dvdplayer
00:23:34 T:3036739328 NOTICE: Default Video Player: dvdplayer
00:23:34 T:3036739328 NOTICE: Default Audio Player: paplayer
00:23:34 T:3036739328 NOTICE: Disabled debug logging due to GUI setting. Level 0.
00:23:34 T:3036739328 NOTICE: Log level changed to 0
00:23:34 T:3036739328 NOTICE: Loading media sources from special://masterprofile/sources.xml
00:23:34 T:3034417984 NOTICE: Thread CSoftAE start, auto delete: false
00:23:34 T:3036739328 NOTICE: Running database version Addons15
00:23:35 T:3024091968 NOTICE: Thread XBMC Peripherals start, auto delete: false
00:23:35 T:3036739328 NOTICE: Setup SDL
00:23:36 T:3036739328 NOTICE: Checking resolution 15
00:23:36 T:3036739328 NOTICE: Using visual 0x21
00:23:36 T:3036739328 NOTICE: GL_VENDOR = Intel Open Source Technology Center
00:23:36 T:3036739328 NOTICE: GL_RENDERER = Mesa DRI Mobile Intel® GM45 Express Chipset x86/MMX/SSE2
00:23:36 T:3036739328 NOTICE: GL_VERSION = 2.1 Mesa 9.2.1
00:23:36 T:3036739328 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
00:23:36 T:3036739328 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_ARB_ES2_compatibility GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_rgb10_a2ui GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_internalformat_query GL_ARB_texture_storage GL_ARB_invalidate_subdata
00:23:36 T:3036739328 NOTICE: Running database version Addons15
00:23:36 T:3036739328 NOTICE: Running database version ViewModes4
00:23:36 T:3036739328 NOTICE: Running database version Textures13
00:23:36 T:3036739328 NOTICE: Running database version MyMusic32
00:23:36 T:3036739328 NOTICE: Running database version MyVideos75
00:23:36 T:3036739328 NOTICE: Running database version TV22
00:23:36 T:3036739328 NOTICE: Running database version Epg7
00:23:36 T:3036739328 NOTICE: start dvd mediatype detection
00:23:36 T:3036739328 NOTICE: initializing playlistplayer
00:23:36 T:3036739328 NOTICE: DONE initializing playlistplayer
00:23:36 T:3026025280 NOTICE: Thread CDetectDVDMedia start, auto delete: false
00:23:37 T:2882362176 NOTICE: Thread XBPyThread start, auto delete: false
00:23:37 T:3036739328 NOTICE: Previous line repeats 5 times.
00:23:37 T:3036739328 NOTICE: initialize done
00:23:37 T:3036739328 NOTICE: Running the application...
00:23:37 T:2815220544 NOTICE: Thread XBPyThread start, auto delete: false
00:23:37 T:2882362176 NOTICE: Previous line repeats 4 times.
00:23:37 T:2882362176 NOTICE: -->Python Interpreter Initialized<--
00:23:37 T:2857184064 NOTICE: -->Python Interpreter Initialized<--
00:23:37 T:2865576768 NOTICE: -->Python Interpreter Initialized<--
00:23:37 T:2848791360 NOTICE: -->Python Interpreter Initialized<--
00:23:37 T:2806827840 NOTICE: -->Python Interpreter Initialized<--
00:23:37 T:2882362176 NOTICE: Thread Jobworker start, auto delete: true
00:23:37 T:3036739328 NOTICE: ES: Starting event server
00:23:37 T:3036739328 NOTICE: starting zeroconf publishing
00:23:37 T:2764962624 NOTICE: Thread CTCPServer start, auto delete: false
00:23:37 T:2773355328 NOTICE: Thread CEventServer start, auto delete: false
00:23:37 T:2773355328 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
00:23:37 T:2773355328 NOTICE: UDP: Listening on port 9777
00:23:37 T:2748177216 NOTICE: Thread Jobworker start, auto delete: true
00:23:38 T:2789448512 NOTICE: Thread CRssReader start, auto delete: false
00:23:38 T:2873969472 NOTICE: -->Python Interpreter Initialized<--
00:23:38 T:2798435136 NOTICE: -->Python Interpreter Initialized<--
00:23:38 T:2840398656 NOTICE: -->Python Interpreter Initialized<--
00:23:38 T:2873969472 NOTICE: Thread CFileCache start, auto delete: false
00:23:38 T:2823613248 NOTICE: -->Python Interpreter Initialized<--
00:23:38 T:2815220544 NOTICE: -->Python Interpreter Initialized<--
00:23:38 T:2832005952 NOTICE: -->Python Interpreter Initialized<--
00:23:38 T:2848791360 NOTICE: Thread CAlarmClock start, auto delete: false
00:23:38 T:2840398656 NOTICE: Thread XBPyThread start, auto delete: false
00:23:39 T:2703219520 NOTICE: Previous line repeats 1 times.
00:23:39 T:2703219520 NOTICE: Thread XBPyThread start, auto delete: false
00:23:39 T:2806827840 NOTICE: Previous line repeats 3 times.
00:23:39 T:2806827840 NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.7.17
00:23:39 T:2806827840 NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup Start
00:23:39 T:2840398656 NOTICE: -->Python Interpreter Initialized<--
00:23:40 T:2857184064 NOTICE: -->Python Interpreter Initialized<--
00:23:40 T:2806827840 NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2014-03-01'
00:23:40 T:2711612224 NOTICE: Thread CFileCache start, auto delete: false
00:23:40 T:2798435136 WARNING: The python script "/home/lorne/.xbmc/addons/script.icechannel/service.py" has left several classes in memory that we couldn't clean up. The classes include: Addon
00:23:40 T:2806827840 NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup End
00:23:40 T:2703219520 NOTICE: -->Python Interpreter Initialized<--
00:23:40 T:2832005952 NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.7.17
00:23:40 T:2832005952 NOTICE: Watch History Module and Service: Auto Cleanup - Start
00:23:40 T:2823613248 NOTICE: PrimeWire: Service: MySQL not enabled or not setup correctly
00:23:40 T:2865576768 NOTICE: -->Python Interpreter Initialized<--
00:23:40 T:2815220544 NOTICE: StorageServer Module loaded RUN
00:23:40 T:2815220544 NOTICE: StorageClient-2.5.4 Starting server
00:23:40 T:2815220544 NOTICE: StorageServer-2.5.4 Storage Server starting /home/lorne/.xbmc/temp/commoncache.db
00:23:40 T:2823613248 NOTICE: PrimeWire: Service: Loading sqlite3 as DB engine
00:23:40 T:2823613248 NOTICE: PrimeWire: Service: Resetting...
00:23:40 T:2832005952 NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2014-03-01'
00:23:40 T:2832005952 NOTICE: Watch History Module and Service: Auto Cleanup - End
00:23:40 T:2823613248 NOTICE: PrimeWire: Service starting...
00:23:41 T:2857184064 NOTICE: iStream: Playlists Code Update Service - Starting\Waking...
00:23:41 T:2873969472 NOTICE: -->Python Interpreter Initialized<--
00:23:41 T:2857184064 NOTICE: iStream: -filestore- -Loading sqlite3 as DB engine version: 3.7.17
00:23:41 T:2865576768 NOTICE: iStream: Subscription Auto Update Service - Starting\Waking...
00:23:42 T:2703219520 NOTICE: iStream: -searchhistory- -Loading sqlite3 as DB engine version: 3.7.17
00:23:42 T:2703219520 NOTICE: iStream: Search History Cleanup Service - Starting\Waking...
00:23:42 T:2865576768 NOTICE: iStream: Subscription Auto Update Service - Auto Update Enabled
00:23:42 T:2832005952 NOTICE: Thread CFileCache start, auto delete: false
00:23:42 T:2873969472 NOTICE: iStream: Cache Cleanup Service - Starting\Waking...
00:23:42 T:2703219520 NOTICE: iStream: -searchhistory- -SELECT DISTINCT indexer_type FROM searchhistory
00:23:42 T:2703219520 NOTICE: iStream: Search History Cleanup Service - Sleeping... Sleep for 300 mins
00:23:42 T:2865576768 NOTICE: iStream: Subscription Auto Update Service - Sleeping... Interval not Reached, Sleep for 1341 mins
00:23:42 T:2873969472 NOTICE: iStream: -netcache- -Loading sqlite3 as DB engine version: 3.7.17
00:23:42 T:2857184064 NOTICE: iStream: Playlists Code Update Service - Sleeping... Sleep for 300 mins
00:23:42 T:2703219520 WARNING: The python script "/home/lorne/.xbmc/addons/script.icechannel/services/cleanupsearchhistory.py" has left several classes in memory that we couldn't clean up. The classes include: Addon
00:23:42 T:2865576768 WARNING: The python script "/home/lorne/.xbmc/addons/script.icechannel/services/updatesubscriptions.py" has left several classes in memory that we couldn't clean up. The classes include: Addon
00:23:42 T:2857184064 WARNING: The python script "/home/lorne/.xbmc/addons/script.icechannel/services/updateplaylistscode.py" has left several classes in memory that we couldn't clean up. The classes include: Addon
00:23:42 T:2873969472 NOTICE: iStream: -netcache- -DELETE FROM netcache WHERE cached < '2014-03-21'
00:23:42 T:2873969472 NOTICE: iStream: Cache Cleanup Service - Sleeping... Sleep for 300 mins
00:23:42 T:2873969472 WARNING: The python script "/home/lorne/.xbmc/addons/script.icechannel/services/cleanupcache.py" has left several classes in memory that we couldn't clean up. The classes include: Addon
00:23:42 T:2840398656 NOTICE: 0 Stale Textures Removed
00:23:42 T:2873969472 NOTICE: Thread CFileCache start, auto delete: false
00:23:43 T:2748177216 NOTICE: Previous line repeats 1 times.
00:23:43 T:2748177216 WARNING: FillBuffer: curl failed with code 22
00:23:43 T:2748177216 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:23:43 T:2748177216 ERROR: Open - failed to open source <http://addons.webspace.virginmedia.com/files/addons.xml.md5>
00:23:44 T:2748177216 WARNING: FillBuffer: curl failed with code 22
00:23:44 T:2748177216 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:23:44 T:2748177216 ERROR: Repository Add-ons by Voinage returned no add-ons, listing may have failed
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
Read the forum http://forum.xbmc.org/showthread.php?tid=189810 and remove your unsupported addons
