2014-03-21, 12:14
What happened to my media everything, me entertainment everythin, my XBMC? It was working just fine the other day. Now whenever I start it up it loads for a second and the just disapears. No crash report or anything.
I tried running it from the terminal and this is what I get when it closes:
Segmentation fault (core dumped)
Crash report available at /home/justin/xbmc_crashlog-20140321_030857.log
I tried updating XBMC through a PPA for Frodo 12.3 but no luck.
Here's the crash log:
Quote:############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri Mar 21 03:08:57 PDT 2014
XBMC Options:
Arch: x86_64
Kernel: Linux 3.11.0-18-generic #32-Ubuntu SMP Tue Feb 18 21:11:14 UTC 2014
Release:
Distributor ID: Ubuntu
Description: Ubuntu 13.10
Release: 13.10
Codename: saucy
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
03:08:49 T:140239553738624 NOTICE: -----------------------------------------------------------------------
03:08:49 T:140239553738624 NOTICE: Starting XBMC (12.3 Git:9ed3e58), Platform: Linux (Ubuntu 13.10, 3.11.0-18-generic x86_64). Built on Dec 13 2013
03:08:49 T:140239553738624 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
03:08:49 T:140239553738624 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
03:08:49 T:140239553738624 NOTICE: special://masterprofile/ is mapped to: /home/justin/.xbmc/userdata
03:08:49 T:140239553738624 NOTICE: special://home/ is mapped to: /home/justin/.xbmc
03:08:49 T:140239553738624 NOTICE: special://temp/ is mapped to: /home/justin/.xbmc/temp
03:08:49 T:140239553738624 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
03:08:49 T:140239553738624 NOTICE: Local hostname: justin-SVT13122CXS
03:08:49 T:140239553738624 NOTICE: Log File is located: /home/justin/.xbmc/temp/xbmc.log
03:08:49 T:140239553738624 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
03:08:49 T:140239553738624 NOTICE: Found 1 Lists of Devices
03:08:49 T:140239553738624 NOTICE: Enumerated ALSA devices:
03:08:49 T:140239553738624 NOTICE: Device 1
03:08:49 T:140239553738624 NOTICE: m_deviceName : default
03:08:49 T:140239553738624 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
03:08:49 T:140239553738624 NOTICE: m_displayNameExtra:
03:08:49 T:140239553738624 NOTICE: m_deviceType : AE_DEVTYPE_PCM
03:08:49 T:140239553738624 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
03:08:49 T:140239553738624 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
03:08:49 T:140239553738624 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
03:08:49 T:140239553738624 NOTICE: Device 2
03:08:49 T:140239553738624 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
03:08:49 T:140239553738624 NOTICE: m_displayName : HDA Intel PCH
03:08:49 T:140239553738624 NOTICE: m_displayNameExtra: HDMI
03:08:49 T:140239553738624 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
03:08:49 T:140239553738624 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
03:08:49 T:140239553738624 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
03:08:49 T:140239553738624 NOTICE: load settings...
03:08:49 T:140239553738624 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: cannot open shared object file: No such file or directory
03:08:49 T:140239553738624 NOTICE: special://profile/ is mapped to: special://masterprofile/
03:08:49 T:140239553738624 NOTICE: loading special://masterprofile/guisettings.xml
03:08:49 T:140239553738624 NOTICE: Getting hardware information now...
03:08:49 T:140239553738624 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
03:08:49 T:140239553738624 NOTICE: Loaded playercorefactory configuration
03:08:49 T:140239553738624 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
03:08:49 T:140239553738624 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
03:08:49 T:140239553738624 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
03:08:49 T:140239553738624 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
03:08:49 T:140239553738624 NOTICE: Default DVD Player: dvdplayer
03:08:49 T:140239553738624 NOTICE: Default Video Player: dvdplayer
03:08:49 T:140239553738624 NOTICE: Default Audio Player: paplayer
03:08:49 T:140239553738624 NOTICE: Disabled debug logging due to GUI setting. Level 0.
03:08:49 T:140239553738624 NOTICE: Log level changed to 0
03:08:49 T:140239553738624 NOTICE: Loading media sources from special://masterprofile/sources.xml
03:08:49 T:140239280195328 NOTICE: Thread CSoftAE start, auto delete: false
03:08:49 T:140239553738624 NOTICE: Running database version Addons15
03:08:49 T:140239262598912 NOTICE: Thread XBMC Peripherals start, auto delete: false
03:08:49 T:140239553738624 NOTICE: Previous line repeats 1 times.
03:08:49 T:140239553738624 NOTICE: Setup SDL
03:08:49 T:140239553738624 NOTICE: Checking resolution 16
03:08:49 T:140239553738624 NOTICE: Using visual 0x21
03:08:49 T:140239553738624 NOTICE: GL_VENDOR = Intel Open Source Technology Center
03:08:49 T:140239553738624 NOTICE: GL_RENDERER = Mesa DRI Intel® Ivybridge Mobile
03:08:49 T:140239553738624 NOTICE: GL_VERSION = 3.0 Mesa 9.2.1
03:08:49 T:140239553738624 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
03:08:49 T:140239553738624 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_internalformat_query GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_ARB_ES3_compatibility GL_ARB_invalidate_subdata GL_ARB_texture_storage_multisample
03:08:49 T:140239553738624 ERROR: GLX: Same window as before, refreshing context
03:08:49 T:140239553738624 NOTICE: Running database version ViewModes4
03:08:49 T:140239553738624 NOTICE: Running database version Textures13
03:08:49 T:140239553738624 NOTICE: Running database version MyMusic32
03:08:49 T:140239553738624 NOTICE: Running database version MyVideos75
03:08:49 T:140239553738624 NOTICE: Running database version TV22
03:08:49 T:140239553738624 NOTICE: Running database version Epg7
03:08:49 T:140239553738624 NOTICE: start dvd mediatype detection
03:08:49 T:140239553738624 NOTICE: initializing playlistplayer
03:08:49 T:140239553738624 NOTICE: DONE initializing playlistplayer
03:08:49 T:140239552345856 NOTICE: Thread CDetectDVDMedia start, auto delete: false
03:08:50 T:140239022335744 NOTICE: Thread XBPyThread start, auto delete: false
03:08:50 T:140238802384640 NOTICE: Previous line repeats 7 times.
03:08:50 T:140238802384640 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140238752028416 NOTICE: Thread XBPyThread start, auto delete: false
03:08:50 T:140239553738624 NOTICE: Previous line repeats 2 times.
03:08:50 T:140239553738624 NOTICE: initialize done
03:08:50 T:140238517163776 NOTICE: Thread XBPyThread start, auto delete: false
03:08:50 T:140239553738624 NOTICE: Running the application...
03:08:50 T:140239553738624 NOTICE: ES: Starting event server
03:08:50 T:140238508771072 NOTICE: Thread CEventServer start, auto delete: false
03:08:50 T:140238508771072 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
03:08:50 T:140238508771072 NOTICE: UDP: Listening on port 9777
03:08:50 T:140238500378368 NOTICE: Thread CTCPServer start, auto delete: false
03:08:50 T:140239553738624 NOTICE: starting zeroconf publishing
03:08:50 T:140238483592960 NOTICE: Thread Jobworker start, auto delete: true
03:08:50 T:140239022335744 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140239013943040 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140238777206528 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140238793991936 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140238752028416 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140238533949184 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140238785599232 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140238517163776 NOTICE: -->Python Interpreter Initialized<--
03:08:50 T:140239013943040 NOTICE: service.libraryautoupdate: Update Library Service starting...
03:08:50 T:140239013943040 NOTICE: service.libraryautoupdate: update timers
03:08:50 T:140238525556480 NOTICE: -->Python Interpreter Initialized<--
03:08:51 T:140238760421120 NOTICE: -->Python Interpreter Initialized<--
03:08:51 T:140238768813824 NOTICE: -->Python Interpreter Initialized<--
03:08:51 T:140238777206528 NOTICE: Artwork Downloader: ## Service - Run at startup: False
03:08:51 T:140238777206528 NOTICE: Artwork Downloader: ## Service - Delayed startup: minutes
03:08:51 T:140238777206528 NOTICE: Artwork Downloader: ## Service - Run as service: False
03:08:51 T:140238777206528 NOTICE: Artwork Downloader: ## Service - Time: :00
03:08:51 T:140238517163776 NOTICE: PrimeWire: Service: MySQL not enabled or not setup correctly
03:08:51 T:140238793991936 NOTICE: Thread CFileCache start, auto delete: false
03:08:51 T:140238517163776 NOTICE: PrimeWire: Service: Loading sqlite3 as DB engine
03:08:51 T:140238517163776 NOTICE: PrimeWire: Service: Resetting...
03:08:51 T:140238533949184 NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.7.17
03:08:51 T:140238533949184 NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup Start
03:08:51 T:140238517163776 NOTICE: PrimeWire: Service starting...
03:08:51 T:140238752028416 NOTICE: StorageServer Module loaded RUN
03:08:51 T:140238752028416 NOTICE: StorageClient-2.5.4 Starting server
03:08:51 T:140238752028416 NOTICE: StorageServer-2.5.4 Storage Server starting /home/justin/.xbmc/temp/commoncache.db
03:08:51 T:140238533949184 NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2014-03-01'
03:08:51 T:140238525556480 NOTICE: Universal - An Addons Toolkit: -watchhistory- -Loading sqlite3 as DB engine version: 3.7.17
03:08:51 T:140238525556480 NOTICE: Watch History Module and Service: Auto Cleanup - Start
03:08:51 T:140238533949184 NOTICE: Universal - An Addons Toolkit: - watchhistory - -Auto Cleanup End
03:08:51 T:140238525556480 NOTICE: Universal - An Addons Toolkit: -watchhistory- -DELETE FROM watch_history WHERE lastwatched < '2014-03-01'
03:08:51 T:140238525556480 NOTICE: Watch History Module and Service: Auto Cleanup - End
03:08:51 T:140239013943040 NOTICE: service.libraryautoupdate: Starting network check
03:08:51 T:140238760421120 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc ...
03:08:51 T:140238760421120 NOTICE: script.tv.show.next.aired: ### upgrading DB from version 2 to 3
03:08:52 T:140239013943040 NOTICE: service.libraryautoupdate: Update Video Library
03:08:52 T:140238768813824 NOTICE: Thread CVideoInfoScanner start, auto delete: false
03:08:52 T:140238768813824 NOTICE: VideoInfoScanner: Starting scan ..
03:08:52 T:140238525556480 NOTICE: Thread CFileCache start, auto delete: false
03:08:54 T:140238793991936 NOTICE: Previous line repeats 2 times.
03:08:54 T:140238793991936 NOTICE: Thread Jobworker start, auto delete: true
03:08:54 T:140238389221120 NOTICE: Thread XBPyThread start, auto delete: false
03:08:54 T:140238389221120 NOTICE: -->Python Interpreter Initialized<--
03:08:54 T:140238380828416 NOTICE: Thread Jobworker start, auto delete: true
03:08:54 T:140238372435712 NOTICE: Thread CAlarmClock start, auto delete: false
03:08:54 T:140238760421120 NOTICE: script.tv.show.next.aired: ### starting data update
03:08:54 T:140237191771904 NOTICE: Thread Jobworker start, auto delete: true
03:08:56 T:140238736586496 NOTICE: Thread CRssReader start, auto delete: false
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
