2014-03-21, 18:54
Hello!!!! this is my first post and i do it here because i don't find the answer .
I have installed xbmcbuntu and it works very very well but i need to use it remotely. I need to use it in graphic mode not in terminal vis ssh or similar.
I have found this instructions and it works fantastic but i need the system execute this command at the beginning (in a terminal, i use Terminator):
x11vnc -forever -usepw -httpdir /usr/share/vnc-java/ -httpport 5800
(source: h**p://lifehacker.com/317125/set-up-vnc-on-ubuntu-in-four-steps)
Then i use TightVNC to connect from a windows 7 PC.
This way works great but when i reboot the xbmc i have to type the command again to do the remote works.
I don't know how to do this automatically without my intervention.
I have tried it in xbmcbuntu but i don't know if this works when the system boot into xbmc.
Can you help me Thank you very much.
PD: i hope you can understand me, i'm spanish and my english is not very good. (but sometimes better than google traductor)
