2014-03-22, 05:20
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri Mar 21 22:09:24 CDT 2014
XBMC Options:
Arch: x86_64
Kernel: Linux 3.11.0-18-generic #32-Ubuntu SMP Tue Feb 18 21:11:14 UTC 2014
Release:
Distributor ID: Ubuntu
Description: Ubuntu 13.10
Release: 13.10
Codename: saucy
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
22:08:00 T:140353141741440 NOTICE: -----------------------------------------------------------------------
22:08:00 T:140353141741440 NOTICE: Starting XBMC (12.3 Git:9ed3e58), Platform: Linux (Ubuntu 13.10, 3.11.0-18-generic x86_64). Built on Dec 13 2013
22:08:00 T:140353141741440 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
22:08:00 T:140353141741440 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
22:08:00 T:140353141741440 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
22:08:00 T:140353141741440 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
22:08:00 T:140353141741440 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
22:08:00 T:140353141741440 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
22:08:00 T:140353141741440 NOTICE: Local hostname: xbmc
22:08:00 T:140353141741440 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
22:08:00 T:140353141741440 WARNING: CXRandR::Query - output VGA1 has no current mode, assuming disconnected
22:08:00 T:140353141741440 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
22:08:00 T:140353141741440 NOTICE: Found 1 Lists of Devices
22:08:00 T:140353141741440 NOTICE: Enumerated ALSA devices:
22:08:00 T:140353141741440 NOTICE: Device 1
22:08:00 T:140353141741440 NOTICE: m_deviceName : default
22:08:00 T:140353141741440 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
22:08:00 T:140353141741440 NOTICE: m_displayNameExtra:
22:08:00 T:140353141741440 NOTICE: m_deviceType : AE_DEVTYPE_PCM
22:08:00 T:140353141741440 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
22:08:00 T:140353141741440 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
22:08:00 T:140353141741440 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
22:08:00 T:140353141741440 NOTICE: Device 2
22:08:00 T:140353141741440 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
22:08:00 T:140353141741440 NOTICE: m_displayName : HDA Intel PCH
22:08:00 T:140353141741440 NOTICE: m_displayNameExtra: ALC283 Analog
22:08:00 T:140353141741440 NOTICE: m_sampleRates : 44100,48000,96000,192000
22:08:00 T:140353141741440 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
22:08:00 T:140353141741440 NOTICE: Device 3
22:08:00 T:140353141741440 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
22:08:00 T:140353141741440 NOTICE: m_displayNameExtra: HDMI #0
22:08:00 T:140353141741440 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:08:00 T:140353141741440 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
22:08:00 T:140353141741440 NOTICE: Device 4
22:08:00 T:140353141741440 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=1
22:08:00 T:140353141741440 NOTICE: m_displayNameExtra: HDMI #1
22:08:00 T:140353141741440 NOTICE: load settings...
22:08:00 T:140353141741440 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: cannot open shared object file: No such file or directory
22:08:00 T:140353141741440 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:08:00 T:140353141741440 NOTICE: loading special://masterprofile/guisettings.xml
22:08:00 T:140353141741440 NOTICE: Getting hardware information now...
22:08:00 T:140353141741440 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:08:00 T:140353141741440 NOTICE: Loaded playercorefactory configuration
22:08:00 T:140353141741440 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:08:00 T:140353141741440 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:08:00 T:140353141741440 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:08:00 T:140353141741440 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:08:00 T:140353141741440 NOTICE: Default DVD Player: dvdplayer
22:08:00 T:140353141741440 NOTICE: Default Video Player: dvdplayer
22:08:00 T:140353141741440 NOTICE: Default Audio Player: paplayer
22:08:00 T:140353141741440 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:08:00 T:140353141741440 NOTICE: Log level changed to 0
22:08:00 T:140353141741440 NOTICE: Loading media sources from special://masterprofile/sources.xml
22:08:00 T:140352870246144 NOTICE: Thread CSoftAE start, auto delete: false
22:08:00 T:140353141741440 NOTICE: Running database version Addons15
22:08:00 T:140352852649728 NOTICE: Thread XBMC Peripherals start, auto delete: false
22:08:00 T:140353141741440 NOTICE: Previous line repeats 1 times.
22:08:00 T:140353141741440 NOTICE: Setup SDL
22:08:00 T:140353141741440 NOTICE: Checking resolution 16
22:08:01 T:140353141741440 NOTICE: Using visual 0x21
22:08:01 T:140353141741440 NOTICE: GL_VENDOR = Intel Open Source Technology Center
22:08:01 T:140353141741440 NOTICE: GL_RENDERER = Mesa DRI Intel(R) Bay Trail
22:08:01 T:140353141741440 NOTICE: GL_VERSION = 3.0 Mesa 9.2.1
22:08:01 T:140353141741440 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
22:08:01 T:140353141741440 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_internalformat_query GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_ARB_ES3_compatibility GL_ARB_invalidate_subdata GL_ARB_texture_storage_multisample
22:08:01 T:140353141741440 ERROR: GLX: Same window as before, refreshing context
22:08:01 T:140353141741440 NOTICE: Running database version Addons15
22:08:01 T:140353141741440 NOTICE: Running database version ViewModes4
22:08:01 T:140353141741440 NOTICE: Running database version Textures13
22:08:01 T:140353141741440 NOTICE: Running database version MyMusic32
22:08:01 T:140353141741440 NOTICE: Running database version MyVideos75
22:08:01 T:140353141741440 NOTICE: Running database version TV22
22:08:01 T:140353141741440 NOTICE: Running database version Epg7
22:08:01 T:140353141741440 NOTICE: start dvd mediatype detection
22:08:01 T:140353141741440 NOTICE: initializing playlistplayer
22:08:01 T:140353141741440 NOTICE: DONE initializing playlistplayer
22:08:01 T:140353140422400 NOTICE: Thread CDetectDVDMedia start, auto delete: false
22:08:02 T:140352118306560 NOTICE: Thread XBPyThread start, auto delete: false
22:08:02 T:140353141741440 NOTICE: Previous line repeats 6 times.
22:08:02 T:140353141741440 NOTICE: UpdateLibraries - Starting video library startup scan
22:08:02 T:140353141741440 NOTICE: initialize done
22:08:02 T:140353141741440 NOTICE: Running the application...
22:08:02 T:140352059557632 NOTICE: Thread CVideoInfoScanner start, auto delete: false
22:08:02 T:140352051164928 NOTICE: Thread XBPyThread start, auto delete: false
22:08:02 T:140352118306560 NOTICE: Previous line repeats 1 times.
22:08:02 T:140352118306560 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140352026081024 NOTICE: Thread Jobworker start, auto delete: true
22:08:02 T:140352109913856 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140352093128448 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140352084735744 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140352067950336 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140351400187648 NOTICE: Thread XBPyThread start, auto delete: false
22:08:02 T:140352042772224 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140352101521152 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140352076343040 NOTICE: -->Python Interpreter Initialized<--
22:08:02 T:140351391794944 NOTICE: Thread Jobworker start, auto delete: true
22:08:02 T:140351383402240 NOTICE: Thread CAlarmClock start, auto delete: false
22:08:02 T:140353141741440 NOTICE: Webserver: Starting...
22:08:02 T:140353141741440 NOTICE: WebServer: Started the webserver
22:08:02 T:140353141741440 NOTICE: starting upnp server
22:08:02 T:140353141741440 NOTICE: starting upnp renderer
22:08:02 T:140353141741440 NOTICE: ES: Starting event server
22:08:02 T:140351209699072 NOTICE: Thread CEventServer start, auto delete: false
22:08:02 T:140351209699072 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
22:08:02 T:140351209699072 NOTICE: UDP: Listening on port 9777
22:08:02 T:140353141741440 NOTICE: starting zeroconf publishing
22:08:02 T:140351192913664 NOTICE: Thread Jobworker start, auto delete: true
22:08:02 T:140351184520960 NOTICE: Thread AirPlayServer start, auto delete: false
22:08:02 T:140351201306368 NOTICE: Thread CTCPServer start, auto delete: false
22:08:02 T:140352059557632 NOTICE: VideoInfoScanner: Starting scan ..
22:08:02 T:140351226484480 NOTICE: Database.eventLoop() >>>>>>>>>> starting...
22:08:02 T:140351226484480 NOTICE: Database.eventLoop() >>>>>>>>>> processing command: _initialize
22:08:02 T:140351176128256 NOTICE: Thread AirTunesServer start, auto delete: false
22:08:02 T:140352076343040 NOTICE: RCB Service: Start
22:08:02 T:140352076343040 NOTICE: RCB Service: launch RCB on startup =
22:08:02 T:140352076343040 NOTICE: RCB Service: scrape games on startup = false
22:08:02 T:140352076343040 NOTICE: RCB Service: Done
22:08:02 T:140351226484480 NOTICE: Settings changed: False
22:08:03 T:140352076343040 NOTICE: Thread Jobworker start, auto delete: true
22:08:03 T:140351226484480 NOTICE: Database.eventLoop() >>>>>>>>>> processing command: _updateChannelAndProgramListCaches
22:08:03 T:140351226484480 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/channels/format/json
22:08:03 T:140351400187648 NOTICE: -->Python Interpreter Initialized<--
22:08:03 T:140352051164928 NOTICE: -->Python Interpreter Initialized<--
22:08:03 T:140351141517056 NOTICE: Thread CFileCache start, auto delete: false
22:08:03 T:140352084735744 NOTICE: Artwork Downloader: ## Service - Run at startup: False
22:08:03 T:140352084735744 NOTICE: Artwork Downloader: ## Service - Delayed startup: minutes
22:08:03 T:140352084735744 NOTICE: Artwork Downloader: ## Service - Run as service: False
22:08:03 T:140352084735744 NOTICE: Artwork Downloader: ## Service - Time: :00
22:08:03 T:140352051164928 NOTICE: PrimeWire: Service: MySQL not enabled or not setup correctly
22:08:03 T:140352042772224 NOTICE: StorageServer Module loaded RUN
22:08:03 T:140352042772224 NOTICE: StorageClient-2.5.4 Starting server
22:08:03 T:140352042772224 NOTICE: StorageServer-2.5.4 Storage Server starting /home/xbmc/.xbmc/temp/commoncache.db
22:08:03 T:140352051164928 NOTICE: PrimeWire: Service: Loading sqlite3 as DB engine
22:08:03 T:140352051164928 NOTICE: PrimeWire: Service: Resetting...
22:08:04 T:140352051164928 NOTICE: PrimeWire: Service starting...
22:08:05 T:140352084735744 NOTICE: Thread CFileCache start, auto delete: false
22:08:07 T:140351226484480 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/programs/tvdate/2014-03-21/channel_id/59/format/json
22:08:09 T:140351226484480 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/programs/tvdate/2014-03-21/channel_id/40/format/json
22:08:11 T:140351226484480 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/programs/tvdate/2014-03-21/channel_id/62/format/json
22:08:13 T:140351226484480 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/programs/tvdate/2014-03-21/channel_id/32/format/json
22:08:14 T:140352059557632 WARNING: Process directory 'smb://SL-SERVER/Drives/TV/More New Movies/12.Years.A.Slave.2013.720p.BluRay.x264-BLOW [PublicHD]/' does not exist - skipping scan.
22:08:14 T:140351226484480 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/programs/tvdate/2014-03-21/channel_id/41/format/json
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
This setup was perfectly fine for the time I had my Baytail NUC can someone help me fix this?
