Full Version: opdenkamp repository: memory corruption
Hi there,
Today I tried an xbmc update from Frodo 12.2 to 12.3 after half a year. I got vdr and xbmc installed. I'm using the vdr-devel overlay (Gentoo), which addresses the opdenkamp git repository.
On vdr site I installed:
- vnsiserver5 (0.9.4)
- xvdr (0.9.9)
On xbmc:
- xbmc-addon-pvr-9999 (Opdenkamp, Git version)
- xbmc-addon-xvdr-9999 (Pipelka, Git version)
I can start vdr with that plugins without problems. But when I try to activate one of the pvr plugins in XBMC (xvdr or vnsi-server) I get:
*** Error in `/usr/lib64/xbmc/xbmc.bin': malloc(): memory corruption: 0x00007f14ac002a20 ***
Then XBMC freezes.
Then I tried to compile vnsi-server of fernet menta, cloned the git branch, but failed, when I called make.
So far I've noticed, there are 3 branches:
  • Fernet Branca: vnsi
  • Opdenkamp: vnsi
  • Pipelka: xvdr
Is one of that 3 somehow usable?
For Frodo you need branch Frodo which holds vnsi3. opdenkamp master is not compatible with 12.x
I recommend that you upgrade XBMC to Gotham beta 2. This version is much better than 12.x.
Quote:*** Error in `/usr/lib64/xbmc/xbmc.bin': malloc(): memory corruption: 0x00007f14ac002a20 ***
Besides that - do a ccache -cC
Haven't activated ccache.
Fernet Menta:
Yes, you're right. I upgraded to Gotham (GIT) and installed Xvdr. It's working great. Thanks.
