Full Version: Flac problem on Minix Neo X7
As a new member I have a problem with the playback of flac and MP3 (320kbps) files on my new Neo X7..
Every time I play songs there are very short clicks in the sound.
I use the latest version of the Minix software with the latest Minix XBMC version.
The XBMC playback of video gives no problem, even a BluRay ISO plays stutter free!
If I use the Explorer to locate the audiofiles (on an external HD) and select a file (flac or mp3) the playback is fine, no clicks.
Also sometimes I can't select a menu item within XBMC or even exit XBMC.
So in my opinion there is a problem with the Minix-XBMC in respect with flac/mp3 audio-files.
Has anyone a suggestion or probably a solution?
Regards,
Willem
Try our version of XBMC, the Gotham beta (use "ARM"): beta (wiki)
