2014-03-24, 17:49
I have a question for using bluray.iso with external player with xbmc gotham.
On my himedia Q10-ii I use xbmc with Himedias Videoplayer as external player (playercorefactory). For almost all videos it works well. For DVD-images I prefer the xbmc-internal-player because of better DVD-navigation. FOR DVD-SD video the performance of the xbmc-DVDPlayer is good enough.
With bluray.iso there are some problems - it does not work. The external player does not start succesfull. The Problem seems to be, that xbmc identifes the *.iso as bluray and starts the internal bluray-menue. Then xbmc starts the external player... but with wrong (additional) parameters.
I'm sure: if xbmc would do nothing special and would only start the *.iso with the external VideoPlayer >> it would work!
When I try the same f.i in ESFileplayer or Mizuu the Videoplayer starts with the bluray-movie.
It should be possible to supress or completely to disable the bluray-Handling of xbmc.
Any idea how to do that?
THANK YOU
SaEt9000
THANK YOU
SaEt9000
