(2014-12-08, 22:27)Tobby Wrote: [ -> ]Damn, I just moved over to the RC build of Helix and I find this. Are there any plans on making it work with Helix? It looks awesome.
Same here. I just updated to Helix, and I just can't find a currently compatible skin that I like. I can't wait for BOX to be updated. I registered for the forums just to make this comment!
Edit: resolve my problem.
(2014-12-29, 05:15)kellygeorge Wrote: [ -> ] (2014-12-08, 22:27)Tobby Wrote: [ -> ]Damn, I just moved over to the RC build of Helix and I find this. Are there any plans on making it work with Helix? It looks awesome.
This sucks indeed
I just assumed it was Helix compatible ... It "kinda" works though, but some menus seem to be empty all of a sudden
This needs to get updated. The best skin for TV without a doubt.
Please update!!!!!
(2015-01-02, 02:49)Scott00007 Wrote: [ -> ]This needs to get updated. The best skin for TV without a doubt.
Please update!!!!!
Activities will continue starting January 20th
DjCisco
Hope you had a relaxing Festive break. For the next release, as well as Kodi compatibility, is there any chance of default artwork for the main menus i.e. a specific background for those times when no fanart exists? That would be awesome
I really love this skin. Am new to xbmc and this skin is what rally pushed me to convert from 7MC which I had heavily customised to my taste. Unfortunately I updated to 14.0 and this skin is currently unavailable
Would love to do a force install of the skin but I cant seem to find the download link for the zip file. Tempted to go back to 13.2 just for this skin...
Whaa my friend said Kodi was out. So installed, but i dont have Box anymore. It was my best Skin for XBMC
Will it made be compatible for Kodi soon?
@DJCisco: Can i get the lastest version from your repo and manual add it to kodi or isnt that wise to do?
Edit: I enabled it again at the disabled addons. I cant just life without this skin
(2015-01-04, 08:02)BaronV Wrote: [ -> ]I really love this skin. Am new to xbmc and this skin is what rally pushed me to convert from 7MC which I had heavily customised to my taste. Unfortunately I updated to 14.0 and this skin is currently unavailable
You can download the skin fromhttps://github.com/DjCisco/skin.box.
If you install the skin that way themes will not work. Also be aware that for Helix several things have changed so some parts of the skin will not work.
(2015-01-03, 12:04)stovies Wrote: [ -> ]DjCisco
First item in my to do list. After thr conversion to helix
Hope you can get it to Helix-compatible soon.
Still think this is the best skin out there - and the wife won't let me change it to something else either
(2014-03-24, 23:59)DjCisco Wrote: [ -> ]There are 5 Main menus : movies , tv shows, music , live tv, an cd/dvd player,live tv has to be enabled under the live tv settings and cd player appears only if there is a cd or dvd to play.
Using other skins the Live TV option works. But under Box the channels load up with excessive load time, and there is never a Live TV icon despite its enabled under settings.
Also have an issue with Weather here in NZ regardless of weather server the function returns no weather data even after correct location is found under settings.
Cheers,
Alistair
a question, I have some Japanese movies and the title doesnt show up because probably it is on japanese characters, is there anyway to solve this?
(2015-01-06, 07:53)Bigalgeorge Wrote: [ -> ] (2014-03-24, 23:59)DjCisco Wrote: [ -> ]There are 5 Main menus : movies , tv shows, music , live tv, an cd/dvd player,live tv has to be enabled under the live tv settings and cd player appears only if there is a cd or dvd to play.
Cheers,
Alistair
Thats a really old post. Thats not true anymore. BOX has no such thing as a Movie, Tv Shows, Music menu etc....
The skin simply has a total of 15 Menus. Each Menu can be individually configured. So if you want to have a menu for live tv yoy have to configure one of the 15 menus to have tiles for live tv.
Weather works fine for me. Maybe you are using weather underground which is now broken. I suggest you change to yahoo weather
