(2015-02-16, 12:18)Prizm4 Wrote: [ -> ]Is it possible to add a Refresh Library icon to the settings area? Unless I'm missing something, I have to exit and restart XBMC everytime I add new files so that it can scan for the new content. Bit of a pain when using a dedicated box for XBMC.
You can find the "Update Library" menu items when browsing a library (movies/tv shows) and opening the "Side" menu.
There at the bottom the update library is available.
--- However: this does not mean I would find it useful to have such a button in the settings area as well ... ---
Libraries. Can be updated via the context menu of a Source, of a tv show or via the view options menu
I am trying to install it in Helix, but i can not find the download link, or the installation instructions in the 1st post. could someone help me_
There is no download link.
The skin is available directly from the official skin repository.
Go to addons-> skins-> Box
If you choose a film from the Homescreen, it doesn´t appears as watched, even if you saw the entire film... XD after that everything looks good.
(2015-02-17, 12:11)emal011 Wrote: [ -> ]If you choose a film from the Homescreen, it doesn´t appears as watched, even if you saw the entire film... XD after that everything looks good.
Do you mean:
A) that it doesnt appear as watched, directly on the Home Screen?
B) that it doesnt appear as watched in the complete movie list.
A) that would be OK depending on which Widget you are using.
B) that would be an error in Kodi itself and not the skin
(2015-02-13, 11:37)Trickass Wrote: [ -> ]Hi DjCisco,
Another thing I've noticed: the "In Progress" TV Shows widget is sorted in a strange way I think. (I don't really know how it is sorted at all...).
I believe it used to be alphabetically, which seemed better to me.
Can this be changed/configured easily?
I have checked this - it is sorted by "last played", it has always been like that.
But yes for organizational purposes I suppose it is better to sort alphabatically by TV Show. I will change that.
HI Community,
I have added Bug Reports Thread and a Feature Request Thread in order to better organize the communication. Please use them accordingly.
(2015-02-16, 16:00)DjCisco Wrote: [ -> ]There is no download link.
Thank you, didint know it was already in the official repository. Great job with the Helix compatibility.
(2015-02-22, 06:00)BaronV Wrote: [ -> ]Secondly, it would be nice to be able to add custom menu icons. Is that possible?
Go to settings->appearance->skin settings->customize home menu
is 3.0.4 version already available?Kodi keeps showing 3.0.2.
Yes 3.0.4 is already available
I don't get it, when I try to do an update, it still says the latest version is 2.7.1. I've uninstalled the skin and reinstalled it and it's still the old version. I'm using an Android version of XBMC, not sure if that makes a difference.
(2015-02-26, 09:32)Prizm4 Wrote: [ -> ]I don't get it, when I try to do an update, it still says the latest version is 2.7.1. I've uninstalled the skin and reinstalled it and it's still the old version. I'm using an Android version of XBMC, not sure if that makes a difference.
You are using xbmc and not kodi.
Update to kodi
ok, I didn't realize you had switched to Kodi only. Thanks.
