2015-02-28, 12:52
(2015-02-14, 20:37)Lionverse Wrote: [ -> ](2015-02-14, 00:55)DjCisco Wrote: [ -> ]Thats recommended, In Progress are those episodes one has started but not yet finished
Sorry, you are correct and thanks again for the updates. I just got my Raspberry Pi 2 and loaded it with OSMC and Box and it is running great! While you are pumping out the updates I thought I would throw out a few requests:
1- You had previously said you could add a toggle to return the album widgets to their previous behavior so selecting am album would have it start to play rather than open the track list.
2- During fullscreen music playback when the info is brought up it would be nice if the clock came up as well
3- When video is paused could there be an option for the info bar to show
4- I'm using the List Info view for TV episodes. Is it possible for the poster there to be the season poster rather than the all seasons poster?
I'm not sure if this last one will go along with your vision for BOX and I get if it doesn't but one thing I do find still missing from other skins is a dedicated episode view like that from Aeon Nox or Neon.
Thanks again for all your hard work and the great skin!
1. Due to the change of implementation on how the widgets work, this is not possible.
2. My philosophy for the info during music playback , is for it to be kept when playing music. Like having a party and letting the music play an everybody can simply see which song is playing. The focus is thus on the music only, So the clock would be out of place.
3. This is easily done, simply, press "i" on your keyboard, or if using a remote, simply map one of the keys to the infodialog.
4. Yes this can be done, I will add it.
5. Unfortunately as you already said , that view type of aeon nox simply doesnt fit with the BOX concept.
