I love the skin that you have created, the simplicity and organization that it has makes it incredibly attractive for me. I think it would fit great on my TV, easy to use and intuitive.
But I have come across a couple of things that I do not know if they are bugs or I just have something wrong with my Kodi or something is missing. I have tried with a clean installation and they are still there.
First, in the main page for movies, there is no way to show the posters of the movies, it only shows its thumbnails, this does not happen with the series.
https://imgur.com/a/sA4Vts3
Second, in the skin edition menu, specifically when choosing the widget, the first three options do not have a name, I can move through them and choose them, but they do not have a name, and curiously they are not translated into Spanish either. (and yes, I've tried in English, and they do not appear either)
https://imgur.com/a/vmByGau
Third, I am sure that this problem is mostly mine because I am Spanish, but it is still annoying, because in the movie genres, the icons do not appear, and I can not change them with an addon. I understand what the problem is, so I unzipped the image pack of the skin, changed the names of the icons so that they were identical to the genres my films have, and it worked. Well, almost, it is not able to catch the accentuation marks well and therefore does not put an icon in the genres with some. No matter how I write it, it does not appear.
https://imgur.com/a/c1mC6oI
Fourth, I know that at this moment you will be hating me, so I'll be brief with this one. I only see the icons of the studios when I go through them, the moment I move to another one, it disappears. I will not say anything that there aren't all there and such because I understand that it is impossible, but it really hurts to know that they are there, but I can only see it if I get on them XD
https://imgur.com/a/R3dBD8p
Ok, those are all my problems, hopefully they can be solved in some way, because I really like the skin, it's really unique, well done!
Now, what would you think about putting the alphabet on the scroll bar when moving between movies and series to let you skip to the first movie with the selected letter? Maybe as a possible extra option?
And if it could be, could there be the option that in poster mode, when moving the camera is centered, instead of stuck to the left? That is, the camera does not move until the selection reaches the center, then begins to follow the selection, until it reaches the end, and returns to stay still.
