2006-03-25, 18:26
this problem is in regards to the latest version i have installed (xbmc-cvs 2006-03-23 by t3ch). when using my universal remote to adjust the volume while playing a video file, the volume increments go something like this: 7.3 > 11.1 > 14.8 etc. if i switch back to the media center screen (where the video is displayed in the bottom right hand corner, the volume adjusts are normal (around 1 db per button push). in general, whenever i am in the media center interface, the volume seems to adjust normally. however, once i get into fullscreen mode, the large increments occur.
it doesn't matter what type of video format i play (mp4, divx, wmv, mpeg).
i'm using a oneforall remote, model urc-6692. in order to adjust the volume, i switch the remote device controller from the xbox to my receiver, which is an rca rt-2600.
the changelog mentions that there was an issue and that it had been resolved (22-03-2006 fixed: volume change with the remote moved in large chunks.), however, it doesn't seem to have worked for me.
anyone else have this problem with this build?
p.s. i have posted this issue here only to find out if it affects others as well. if so, i will post this issue in the official bug tracking system at sourceforge.
