2014-03-25, 11:36
Hi I'm new to xbmc and have a problem I have searched on line for help but have no luck. When I go to open xbmc it opens for about 5 secs and then closes. The crash log is detailed below maybe it could explain what is going wrong. I would greatly appreciate any help as I have been trying to solve this issue for about 5 days
[/php][/quote]
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Tue Mar 25 09:12:28 GMT 2014
XBMC Options:
Arch: i686
Kernel: Linux 3.13.0-19-generic #40-Ubuntu SMP Mon Mar 24 02:37:00 UTC 2014
Release:
Distributor ID: Ubuntu
Description: Ubuntu Trusty Tahr (development branch)
Release: 14.04
Codename: trusty
############## END SYSTEM INFO ##############
############### STACK TRACE #################
############# END STACK TRACE ###############
################# LOG FILE ##################
09:12:00 T:3010742912 NOTICE: -----------------------------------------------------------------------
09:12:00 T:3010742912 NOTICE: Starting XBMC from Debian (12.3 Debian package version:2:12.3+dfsg1-3ubuntu1), Platform: Linux (Ubuntu Trusty Tahr (development branch), 3.13.0-19-generic i686). Built on Jan 7 2014
09:12:00 T:3010742912 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
09:12:00 T:3010742912 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
09:12:00 T:3010742912 NOTICE: special://masterprofile/ is mapped to: /home/bee/.xbmc/userdata
09:12:00 T:3010742912 NOTICE: special://home/ is mapped to: /home/bee/.xbmc
09:12:00 T:3010742912 NOTICE: special://temp/ is mapped to: /home/bee/.xbmc/temp
09:12:00 T:3010742912 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
09:12:00 T:3010742912 NOTICE: Local hostname: bee-Precision-M6300
09:12:00 T:3010742912 NOTICE: Log File is located: /home/bee/.xbmc/temp/xbmc.log
09:12:01 T:3010742912 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
09:12:01 T:3010742912 NOTICE: Found 1 Lists of Devices
09:12:01 T:3010742912 NOTICE: Enumerated ALSA devices:
09:12:01 T:3010742912 NOTICE: Device 1
09:12:01 T:3010742912 NOTICE: m_deviceName : default
09:12:01 T:3010742912 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
09:12:01 T:3010742912 NOTICE: m_displayNameExtra:
09:12:01 T:3010742912 NOTICE: m_deviceType : AE_DEVTYPE_PCM
09:12:01 T:3010742912 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
09:12:01 T:3010742912 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
09:12:01 T:3010742912 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
09:12:01 T:3010742912 NOTICE: Device 2
09:12:01 T:3010742912 NOTICE: m_deviceName : pulse
09:12:01 T:3010742912 NOTICE: m_displayName : PulseAudio Sound Server
09:12:01 T:3010742912 NOTICE: Device 3
09:12:01 T:3010742912 NOTICE: m_deviceName : @:CARD=Intel,DEV=0
09:12:01 T:3010742912 NOTICE: m_displayName : HDA Intel
09:12:01 T:3010742912 NOTICE: m_displayNameExtra: STAC9205 Analog
09:12:01 T:3010742912 NOTICE: m_sampleRates : 44100,48000,88200,96000,192000
09:12:01 T:3010742912 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
09:12:01 T:3010742912 NOTICE: Device 4
09:12:01 T:3010742912 NOTICE: m_deviceName : iec958:CARD=Intel,DEV=0
09:12:01 T:3010742912 NOTICE: m_displayNameExtra: STAC9205 Digital S/PDIF
09:12:01 T:3010742912 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
09:12:01 T:3010742912 NOTICE: load settings...
09:12:01 T:3010742912 NOTICE: special://profile/ is mapped to: special://masterprofile/
09:12:01 T:3010742912 NOTICE: loading special://masterprofile/guisettings.xml
09:12:01 T:3010742912 NOTICE: Getting hardware information now...
09:12:01 T:3010742912 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
09:12:01 T:3010742912 NOTICE: Loaded playercorefactory configuration
09:12:01 T:3010742912 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
09:12:01 T:3010742912 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
09:12:01 T:3010742912 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
09:12:01 T:3010742912 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
09:12:01 T:3010742912 NOTICE: Default DVD Player: dvdplayer
09:12:01 T:3010742912 NOTICE: Default Video Player: dvdplayer
09:12:01 T:3010742912 NOTICE: Default Audio Player: paplayer
09:12:01 T:3010742912 NOTICE: Disabled debug logging due to GUI setting. Level 0.
09:12:01 T:3010742912 NOTICE: Log level changed to 0
09:12:01 T:3010742912 NOTICE: Loading media sources from special://masterprofile/sources.xml
09:12:01 T:2998696768 NOTICE: Thread CSoftAE start, auto delete: false
09:12:01 T:3010742912 NOTICE: Running database version Addons15
09:12:03 T:2988440384 NOTICE: Thread XBMC Peripherals start, auto delete: false
09:12:03 T:3010742912 NOTICE: Setup SDL
09:12:03 T:3010742912 NOTICE: Checking resolution 15
09:12:03 T:3010742912 NOTICE: Using visual 0x18d
09:12:03 T:3010742912 NOTICE: GL_VENDOR = nouveau
09:12:03 T:3010742912 NOTICE: GL_RENDERER = Gallium 0.4 on NV92
09:12:03 T:3010742912 NOTICE: GL_VERSION = 3.0 Mesa 10.1.0
09:12:03 T:3010742912 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
09:12:03 T:3010742912 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_multisample GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_NV_vdpau_interop GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_base_instance GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge
09:12:04 T:3010742912 NOTICE: Running database version Addons15
09:12:04 T:3010742912 NOTICE: Running database version ViewModes4
09:12:04 T:3010742912 NOTICE: Running database version Textures13
09:12:04 T:3010742912 NOTICE: Running database version MyMusic32
09:12:04 T:3010742912 NOTICE: Running database version MyVideos75
09:12:04 T:3010742912 NOTICE: Running database version TV22
09:12:04 T:3010742912 NOTICE: Running database version Epg7
09:12:04 T:3010742912 NOTICE: start dvd mediatype detection
09:12:04 T:3010742912 NOTICE: initializing playlistplayer
09:12:04 T:3010742912 NOTICE: DONE initializing playlistplayer
09:12:04 T:2990304064 NOTICE: Thread CDetectDVDMedia start, auto delete: false
09:12:04 T:2849307456 NOTICE: Thread XBPyThread start, auto delete: false
09:12:04 T:3010742912 NOTICE: Previous line repeats 7 times.
09:12:04 T:3010742912 NOTICE: initialize done
09:12:04 T:2773773120 NOTICE: Thread XBPyThread start, auto delete: false
09:12:04 T:3010742912 NOTICE: Running the application...
09:12:04 T:2782165824 NOTICE: Thread XBPyThread start, auto delete: false
09:12:04 T:2824129344 NOTICE: -->Python Interpreter Initialized<--
09:12:04 T:2849307456 NOTICE: -->Python Interpreter Initialized<--
09:12:04 T:2840914752 NOTICE: -->Python Interpreter Initialized<--
09:12:04 T:2790558528 NOTICE: -->Python Interpreter Initialized<--
09:12:04 T:2832522048 NOTICE: -->Python Interpreter Initialized<--
09:12:04 T:2773773120 NOTICE: -->Python Interpreter Initialized<--
09:12:04 T:2815736640 NOTICE: -->Python Interpreter Initialized<--
09:12:04 T:2798951232 NOTICE: -->Python Interpreter Initialized<--
09:12:05 T:2807343936 NOTICE: -->Python Interpreter Initialized<--
09:12:05 T:2832522048 NOTICE: Thread Jobworker start, auto delete: true
09:12:05 T:3010742912 NOTICE: Webserver: Starting...
09:12:05 T:3010742912 NOTICE: WebServer: Started the webserver
09:12:05 T:3010742912 NOTICE: starting upnp renderer
09:12:05 T:3010742912 NOTICE: ES: Starting event server
09:12:05 T:2715024192 NOTICE: Thread CEventServer start, auto delete: false
09:12:05 T:2715024192 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
09:12:05 T:2715024192 NOTICE: UDP: Listening on port 9777
09:12:05 T:3010742912 NOTICE: starting zeroconf publishing
09:12:05 T:2706631488 NOTICE: Thread CTCPServer start, auto delete: false
09:12:05 T:2698238784 NOTICE: Thread Jobworker start, auto delete: true
09:12:05 T:2689846080 NOTICE: Thread AirPlayServer start, auto delete: false
09:12:05 T:2681453376 NOTICE: Thread Jobworker start, auto delete: true
09:12:05 T:2673060672 NOTICE: Thread AirTunesServer start, auto delete: false
09:12:05 T:2656369472 NOTICE: Thread Jobworker start, auto delete: true
09:12:05 T:2943757120 NOTICE: Thread CRssReader start, auto delete: false
09:12:05 T:2782165824 NOTICE: -->Python Interpreter Initialized<--
09:12:05 T:2647976768 NOTICE: Thread CFileCache start, auto delete: false
09:12:05 T:2798951232 NOTICE: PrimeWire: Service: MySQL not enabled or not setup correctly
09:12:06 T:2798951232 NOTICE: PrimeWire: Service: Loading sqlite3 as DB engine
09:12:06 T:2798951232 NOTICE: PrimeWire: Service: Resetting...
09:12:06 T:2798951232 NOTICE: PrimeWire: Service starting...
09:12:06 T:2815736640 NOTICE: StorageServer Module loaded RUN
09:12:06 T:2815736640 NOTICE: StorageClient-2.5.4 Starting server
09:12:06 T:2815736640 NOTICE: StorageServer-2.5.4 Storage Server starting /home/bee/.xbmc/temp/commoncache.db
09:12:06 T:2790558528 NOTICE: [TV4ME] Subscription service starting...
09:12:07 T:2782165824 NOTICE: [MovieStorm] Subscription service starting...
09:12:07 T:2824129344 NOTICE: Thread XBPyThread start, auto delete: false
09:12:07 T:2824129344 NOTICE: -->Python Interpreter Initialized<--
09:12:07 T:2824129344 NOTICE: CommonFunctions-2.5.1
09:12:07 T:2824129344 NOTICE: metahandler: Initializing MetaHandlers version: 2.4.0
09:12:07 T:2824129344 NOTICE: metahandler: Loading sqlite3 as DB engine version: 3.8.2
09:12:07 T:2824129344 NOTICE: Previous line repeats 1 times.
09:12:07 T:2824129344 WARNING: Attempt to use invalid handle -1
09:12:07 T:2824129344 WARNING: Previous line repeats 1 times.
09:12:07 T:2824129344 NOTICE: Thread CVideoInfoScanner start, auto delete: false
09:12:07 T:2824129344 NOTICE: VideoInfoScanner: Starting scan ..
09:12:07 T:2824129344 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
[/php][/quote]
XBMC Options:
Arch: i686
Release:
Release: 14.04
Codename: trusty
