2014-03-25, 18:41
I just added a intel NUC I3 to my existing setup. I copied over sources, mediasources and advancedsettings xml files from my existing ATV 2 to Xubuntu 13.10 on the NUC.
Everything is still working correctly on both of my ATV's identical shares and DB
When I scan for new content on any of my media sources it instantly freezes. Also when I play a video I get audio but the screen is black and it completly freezes
Any ideas?
I have removed XBMC and re-installed it a few times, I had started on XBMC 12.3 then moved to 13 Beta 2
P.S. If I create the sources and media sources in XBMC they seem to work, but it doesn't see my MYSQL library via the advanced settings.xml
The smb share contains 2 video sources as well as is my MYSQL server running linux
The NFS shares are from OSX 10.9.2 and just media shares
The xml files from Atv I am using Adv, mediasources and sources.xml:
http://pastebin.com/UkhYQgMj
Log file:
after scan for new content :
http://pastebin.com/9uxtE9zD
Log file after playing video (got audio and black screen):
http://pastebin.com/zaiaF488
Log file after manually adding sources and mediasouces via XBMC (libary not found):
http://pastebin.com/p5P2vGtz
Any ideas?
Log file:
