Full Version: 14 Day EPG has changed to 4?
Before Gotham I used to have a 14 Day EPG guide but the option to choose how many days has disappeared from the settings screen?
How can I change this back to 14?
Many Thanks
Sorry, just discovered the new advanced/standard settings option!
The setting is still there. you have to change the settings level to "advanced" to show/change this option.
Thank you, I mentioned on my post that after hours of trying to work it out (was using Xperience 1080++ Skin and the option is not on there), I found that option on confluence just after posting on here
Cheers
(2014-03-26, 10:46)mbc0 Wrote: [ -> ]Thank you, I mentioned on my post that after hours of trying to work it out (was using Xperience 1080++ Skin and the option is not on there), I found that option on confluence just after posting on here
Cheers
Hi there, the option is there (at least for me on Xperience 1080++), when you select the Live TV section you press Left to pull up the configuration menu that allows you to set it as Expert, Beginner etc
Cheers
