2006-03-25, 23:17
i have softmodded my xbox using xbmc and i recently got the component cables to hook it up to my hdtv. i read that you have to go back to the unleashx or microsoft dashboards to enable hdtv resolutions.
can i take a backup of my e/dashboard(xbmc) using flashfxp and then reinstall krayzie's ndure exploit to get the unleash x dashboard. then go into unleashx dashboard settings to enable hdtv resolutions.
after that can i restore my backed up xbmc dashboard and then go into its settings, look and feel and change resolutions to get 16:9 hdtv resolutions?
or is there a better way of doing this.
the kryzie ndure installer made a shadow backup of my c drive and also of the eeprom. what are these backups for?
thanks
thanks
