2014-05-24, 15:39
Actually I just tried on my Raspberry Pi and I do get a black screen on that. On my Revo I get a picture but no sound. I guess I'll also be downgrading to the previous firmware!
(2014-05-04, 22:29)Leopold Wrote: [ -> ]After doing a search on the Foscam forum it seems that model does have a different interface to the newer HD cameras
(2014-06-03, 19:40)Piet Mosh Wrote: [ -> ](2014-05-04, 22:29)Leopold Wrote: [ -> ]After doing a search on the Foscam forum it seems that model does have a different interface to the newer HD cameras
Hi Leo,
I´m back and finally got my 9821W V2 but maybe I am still too stupid. ^^
Can´t get it to work.
Can you name your settings in the web interface and add on?
Ain´t getting an error message, clicking on Foscam HD just brings me back to the add on settings.
Log In as Admin or different user?
Please help.
Thanx
piet
System Firmware Version 1.4.1.9
Application Firmware Version 2.11.2.8
Plug-In Version 2.0.2.10
(2014-06-03, 21:54)Piet Mosh Wrote: [ -> ]small update:
starting the add on manually by click I got the picture (ip adress without http://), but motion detection ist still not working
(2014-06-03, 23:48)stevedawg85 Wrote: [ -> ]Thanks man, looks awesome. Will definitely try! I have 2 Foscam's, does this work with both @ the same time?At the moment it's only for one camera at a time. I did start working on a version to support more than one camera, and I plan to pick that up again at some point. The tricky bit is how to handle motion events from more than one camera, so I'll have more of a think about that.
(2014-06-04, 10:39)Leopold Wrote: [ -> ](2014-06-03, 23:48)stevedawg85 Wrote: [ -> ]Thanks man, looks awesome. Will definitely try! I have 2 Foscam's, does this work with both @ the same time?At the moment it's only for one camera at a time. I did start working on a version to support more than one camera, and I plan to pick that up again at some point. The tricky bit is how to handle motion events from more than one camera, so I'll have more of a think about that.
(2014-06-04, 10:39)Leopold Wrote: [ -> ]At the moment it's only for one camera at a time. I did start working on a version to support more than one camera, and I plan to pick that up again at some point. The tricky bit is how to handle motion events from more than one camera, so I'll have more of a think about that.
(2014-06-29, 13:53)WolvesPhil Wrote: [ -> ]I am struggling to get this to connect using XBMC 13.1.I've not been on the forums lately so have only just seen your post. I have just checked and I am able to connect using the XBMC 13.1. Can you post a log file?
I am able to connect to the foscam test cameras in a web browser but in XBMC I get 'error connecting to camera, please check your network connection and the camera settings'
All I have changed in the addon is the IP / port / user and password
(2014-07-18, 13:09)Leopold Wrote: [ -> ](2014-06-29, 13:53)WolvesPhil Wrote: [ -> ]I am struggling to get this to connect using XBMC 13.1.I've not been on the forums lately so have only just seen your post. I have just checked and I am able to connect using the XBMC 13.1. Can you post a log file?
