I've released 0.0.19 which adds checks for characters which will cause problems for this add-on but are allowed by Foscam. These characters are
for the password, and
for the user name.
(2014-09-22, 15:48)Leopold Wrote: [ -> ]Are you using a user account with admin privileges?
Next time I get to the installation location I will check that. Thanks!
(2014-09-30, 20:55)nickr Wrote: [ -> ] (2014-09-30, 16:11)xavier.ba Wrote: [ -> ]Crashes
What?
Helpful critique isn't it.
Hi, so I double checked and the account I am trying to connect with is a admin account. Here are the logs from when I try to connect.
18:08:40 T:4008 NOTICE: -->Python Interpreter Initialized<--
18:08:41 T:4008 NOTICE: script.foscam v0.0.19:
http://192.168.0.202:88/cgi-bin/CGIProxy...******&pwd=***********
18:08:41 T:4008 NOTICE: script.foscam v0.0.19: <Response [200]>
18:08:41 T:4008 NOTICE: script.foscam v0.0.19: <CGI_Result>
<result>-2</result>
</CGI_Result>
18:08:41 T:4008 ERROR: script.foscam v0.0.19: Username or password error
18:08:44 T:3828 NOTICE: script.foscam v0.0.19: Sleeping for 5 seconds
I also double and triple checked the username and password for the account.
(2014-10-02, 06:15)sea3pea0 Wrote: [ -> ]Hi, so I double checked and the account I am trying to connect with is a admin account. Here are the logs from when I try to connect.
18:08:41 T:4008 NOTICE: script.foscam v0.0.19: http://192.168.0.202:88/cgi-bin/CGIProxy...******&pwd=***********
<result>-2</result>
</CGI_Result>
Try the http request in a browser and see what you get
http://192.168.0.202:88/cgi-bin/CGIProxy.fcgi?cmd=getDevState&usr=username&pwd=password
(2014-10-03, 22:46)sea3pea0 Wrote: [ -> ] (2014-10-02, 07:43)Leopold Wrote: [ -> ]Try the http request in a browser and see what you get
This is what I get:
<CGI_Result>
<result>-2</result>
</CGI_Result>
OK so the problem is not related to the add-on itself. -2 means "Username or password error".
Well even though I could login with that username & password combo through the camera's webpage, I guess the cgi interface didn't like something about the username password combo I was using. So after creating a new user & password I got it working. Thanks for your help.
(2014-10-04, 22:06)sea3pea0 Wrote: [ -> ]Well even though I could login with that username & password combo through the camera's webpage, I guess the cgi interface didn't like something about the username password combo I was using. So after creating a new user & password I got it working. Thanks for your help.
Could you paste your original url with the problem user/password into
http://www.url-encode-decode.com/ and try the resultant encoded url? I'd be interested to know if this fixes it as I could do the same thing in the add-on. The Foscam documentation is a bit unclear about this.
I currently have two Non-HD Foscam (FI8910W) camera's that are not supported with this addon. I would love to buy a new one just to make this add-on work. In reading through the thread it appears there are some HD Foscam firwares/versions that don't work properly (if I read the comments right). Can anyone tell me if the below statement is still true? I was looking at one on ebay and wanted to save myself sometime if I could get the exact version that is guaranteed to work. Thanks everyone!
From OP
"I tested with a FI9821W V2 that I use as a baby monitor but it should work with any of the HD range, so anything with a model number starting with FI98."
I still only have a FI9821W V2 so can only speak for that. I'm running the latest firmware (V-2.x.1.10_20140516) with a
patch from Foscam applied to fix the audio.
All the FI98 models share the same API and rtsp URLs so should all work with this add-on. Hopefully others can reply with their actual experience of the other HD models. Does anyone use a FI9831W with this add-on?
(2014-10-05, 11:32)Leopold Wrote: [ -> ]Could you paste your original url with the problem user/password into http://www.url-encode-decode.com/ and try the resultant encoded url? I'd be interested to know if this fixes it as I could do the same thing in the add-on. The Foscam documentation is a bit unclear about this.
I tried pasting the encoded url into a browser but because the ip address was encoded as well it just opened up a google search for the encoded url. I also tried just encoding from "cgi" on instead of encoding the
http://ipaddress:88/ part but that gave me a 404 error.
(2014-09-20, 22:40)Leopold Wrote: [ -> ] (2014-09-19, 07:27)vamana Wrote: [ -> ]I'm trying to install Foscam HD in XBMC 13.2 but couldn't. It says "Add-on is incompatible or has been marked broken in repository. Dependencies not met. Please contact Add-on author"
Is there any extra setting I need to do?
thanks
This should be fixed now.
I have the same message in 12.1, is 13 required for this add-on?
I just downloaded the repo from your 1st post and tried to enabled the add-on but it's listed as Broken.
