2014-11-10, 12:28
(2014-11-10, 07:59)danillll Wrote: [ -> ]Hi Leo,Thanks for the links. I'll definitely look into it.
I am currently shopping for a baby monitor and was super excited when I read about your plugin until I got to the last couple of posts regarding the delay.
As you stated, the issue is not on the xbmc/addon side, it's in the RSTP on the server side (ie: the camera)
http://foscam.us/forum/high-def-performance-t8083.html
From the above link, the only solution is to access the stream directly and the fact that the sdk for the low level h.264 is not documented, I guess the only solution right now is to reverse engineer it.
I am not sure if this https://github.com/MStrecke/pyFosControl will be helpful.
