Im stumped.
I have tried multiple changes to the asound.conf as well and looking into the squeezebox addon files with no luck getting this resolved.
I added the config file by following the wiki (
http://wiki.openelec.tv/index.php/Config...menusound) and double checked it had created ok, which it had, and still no luck getting the squeeze box to work
http://pastebin.com/MNPSjTux
I am running:
Gotham OE Beta 2
DC7700
HD5450
Current error saying "could not connect to player"
The player is installed, and i have tested my LMS by installing a client on my Win8 box and tested it working
Any ideas?
Any other OpenElec users have this working?
N
I'll repeat what I said in the main thread
1. get it working from the command line first (see wiki)
2. I think alsa is stuff as you'ev got all this:
NFO: CAESinkALSA - ALSA: /home/stephan/projects/openelec-4.0/build.OpenELEC-Generic.x86_64-3.95.2/alsa-lib-1.0.27.2/src/pcm/pcm_dmix.c:1022
snd_pcm_dmix_open) unable to open slave
...going on and I don't think you should. Ask over the OE forums about that maybe.
Also - that addon is XSqueeze. Not squeezebox, which is a hardware player.
what does running "squeezelite -l" from the command line/ssh spit out? as bossanova said, get squeezelite running manually and playing via LMS first. then map Xsqueeze to the running squeezelite process before trying to have Xsqueeze start and stop the process itself. crawl, walk, run.
Make sure, you suspend ActiveAE when starting it. It's easy possible via xbmc python api. Alsa does not do any dmix by default, therefore you need to take care for that.
Hi chaps.
So thanks to everyone, i am making progress...
I didnt seem to have full rights to the squeezelite-i64 files so i have changed that and i can now run it from SSH
Lounge:~/.xbmc/addons/script.xsqueeze/resources/bin/linux # ./squeezeslave-
i64 -ls
./squeezeslave-i64: unrecognized option '-s'
PortAudio error7: No output devices found.
Any ideas
N
just tried it again and got this:
Connect to LCDd failed!
Error connecting to 127.0.0.1:3483
Connection to Squeezebox Server 127.0.0.1 failed.
Lounge:~/.xbmc/addons/script.xsqueeze/resources/bin/linux # ./squeezeslave-i64
Lounge:~/.xbmc/addons/script.xsqueeze/resources/bin/linux # ./squeezelite-i64
[19:26:09.081060] test_open:124 playback open error: No such file or directory
[19:26:09.081121] output_init_common:372 unable to open output device
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
hdmi:CARD=HDMI,DEV=0 - HDA ATI HDMI, HDMI 0 - HDMI Audio Output
Well -s is not an option for squeezeslave.
Also you need to specify the server, or use -F.
Run with --help to get all options.
Lounge:~/.xbmc/addons/script.xsqueeze/resources/bin/linux # ./squeezeslave-i64 l 192.168.1.200
(2014-03-28, 23:47)nick w Wrote: [ -> ]Lounge:~/.xbmc/addons/script.xsqueeze/resources/bin/linux # ./squeezeslave-i64 l 192.168.1.200
Why do you have the | in there between the i64 and the IP address?
its an letter l
i64 192.168.1.200
But removing it, i still get no output devices found... strange
any ideas how to set the output?
@ nick w - take it to the main thread please.
its -l not -i (i.e. minus l, not minus i)
