2014-03-27, 00:19
I've stumble upon this thing lately and I can't figure it out.
I have a movie in XBMC library - Alexander. While browsing movie library, everything is ok - fanart, folder image, playback - all works fine.
When browsing the same movie but in VIDEOS section - i got no thumbnail (blue folder appears instead) and xbmc is acting like there was no such position in library (using "movie info" command gives me window trying to add this position into library)
Funny thing is - i have this movie in folder: Alexander -Revisited (The Final Cut)[720p][dts]
After changing folder name to: Alexander -Revisited (The Final Cut)[720p][DTS] everything goes back to normal, images are displayed correctly, everything is fine.
How can i fix it (other than the obvious - changing path part from dts to DTS)?
I tried editing MyVideos75.db but it gives me nothing.
If it was just for this one movie - deleting and importing it does the work, but there is about 70 of such movies, so it makes it a little bit more time consuming.
