Full Version: Display issue
Hi i have the latest release of XBMC, i really like the software, but i have run into a small issue, I have a 28' PC monitor as screen1 and my 50' HDTV as screen2, while i can get xbmc to display on my TV when i move my mouse back to screen1 and load any program, it minimizes the xbmc on screen2. I want to be able to work/play a game or whatever on screen1 without xbmc minimizing on screen2. I'm sure i'm just missing a simple setting to stop this from happening, but i cannot find what that setting might be. my PC specs are as follows.
I7 [email protected]
12g ram
120 SSD (force gs)
1tb 7200rpm WD black drive
Sapphire VaporX AMD Radeon 5870
Win 7 x64 ultimate, newest Service pack and updates.
I'm using an HDMI connection from the video card to TV.
Any help would be great, thanks.
EDIT-found the problem, needed to select the "use fullscreen window instead of true fullscreen." incase anyone else has this issue.
Mike
My first though exactly. Might want to add a [SOLVED] tag to the initial post heading.
