Full Version: ebay media boxes suggestions
hi guys i bought a new android media player from aldi this week. its totally useless. eill be returning it tomorrow. i was this one on ebay
http://www.ebay.com.au/itm/Quad-Core-8GB...462&_uhb=1
or
http://www.ebay.com.au/itm/MX-Android-4-...4fe&_uhb=1
but wanted to know if it was any good. or if there are better ones out there for around the same money.
all help would be appreciated
regards
Taza
(2014-03-28, 12:19)Taza13 Wrote: [ -> ]hi guys i bought a new android media player from aldi this week. its totally useless. eill be returning it tomorrow. i was this one on ebay
or
regards
Taza
For the first one have a look here:
http://forum.xbmc.org/showthread.php?tid=180251
The second is almost the same as my box, except mine is an M6. From what I understand the really isn't any difference between the Amlogic MX and M6.
I am by far not an expert, but from what I have read the Amlogic dual core boxes are the way to go.
I just flashed a different firmware this morning and installed the latest XBMC Gotham Beta 2. It played 1080p extremely well compared to a beta firmware I was running.
However, if I were to buy a box today, I would probably go with an Odroid U3 (or better) with a 16GB eMMC. http://www.hardkernel.com/main/main.php
Have a look here for hardware decoding on various Android boxes: http://wiki.xbmc.org/index.php?title=Android_hardware
thanks im a noob to all this. amlogic chipsets are good as they are able to process H.264 & other common codecs,MPEG-2, VC-1 / WMV 9 as well as the samsung 4412 chipset. is that right?
with the one you would get its only the chip right id have to build a shell for it?
does yours do 1080p with ease?
cheers
Taza
i need the android because i need to run hulu+ netflix smoothly on one of these units
what about this? http://www.ebay.com/itm/Quad-Core-8GB-An...485edb7efc
is it native 1080p?
It's not bad, but I would go with the Odroid U3. You'll end up paying about the same, and it will have a lot more power.
(2014-03-29, 04:10)Ned Scott Wrote: [ -> ]It's not bad, but I would go with the Odroid U3. You'll end up paying about the same, and it will have a lot more power.
but isnt it just a chip what else do i need im a bit of a noob re this? and will i be able to run netflix, hulu and xbmc?
cheers
(2014-03-29, 04:57)Taza13 Wrote: [ -> ]
cheers
From that website you buy the board, case, power plug, wifi, memory card (for system/XBMC), the HDMI cable, and the final cost with shipping will be about $100.
