Full Version: i'm developing a webinterface with language supprt.
hi community,
currently i am working at an webinterface which is also good for mobilephone and tablet use.
one thing i missed always is the support of language-tags in xbmc. in my solution, i parse language informations out of the filename.
example: i digitized all my dvd's and added language tags in the format _DE_ for german.
so the filename for Breaveheart is in my case: Breaveheart_DE_ES.iso (so German and Spanish).
but since i am planing to soon release a beta of my webinterface to the public, ppl would surely like to have support for their tag-philosophy.
so what are the tags you use?
so far i have for german: "_DE", "[Ger]", ".German.", ".GERMAN."
what other formats are used out there?
help apreciated.
Why not just read the audio streams in the file? By that I mean XBMC reads them and makes them available via the JSONRPC.
oh very nice, i have a look into it! thanks for the hint!
hehe, not one of my movies has the audio stream info (well i have only *.iso files, which seems not supported). so i am thinking about a setting where you can choose if it shall use "my"-version or the feature of xbmc.
so thanks a lot for your suggestion, did not know xbmc has this feature...
