Full Version: XBMC fails to start on UBUNTU 12.04
Dear friends can you help ??
I installed XBMC on UBUNTU 12.04 typing the following in Terminal:
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install xbmc
When I try to run XBMC from Dash Home, nothing happens.
When I try to run from Terminal I get :
[email protected]:~$ xbmc
/usr/lib/xbmc/xbmc.bin: symbol lookup error: /usr/lib/xbmc/xbmc.bin: undefined symbol: _ZTIN6TagLib5ID3v219Latin1StringHandlerE
See the log in
http://paste.ubuntu.com/7180695/
I use an ACER 1640 laptop with Intel 950 as a graphics card.
I already tried to uninstall and reinstall but nothing happened.
Any thoughts welcome
Thanks in advance
Starting XBMC (11.0 Git:Unknown)...
Thats not xbmc from our PPA.
(2014-03-30, 21:04)wsnipex Wrote: [ -> ]Starting XBMC (11.0 Git:Unknown)...
What do you mean Huh
I installed the XBMC the way I told you.
Any Ideas or suggestions?
If thats the problem why isn't it fixed when I uninstall and reinstall it Huh
Can you post the output of apt-cache policy xbmc, please - let's see what you've got and where it came from...
Other thoughts for you... Google brought these up easily enough:
http://forum.xbmc.org/showthread.php?tid=154072
http://forum.xbmc.org/showthread.php?tid=154431
http://forum.xbmc.org/showthread.php?tid=154096
