Full Version: Context Menu not working.....? Help!
Hi Guys,
I'm still using SPMC on my ouya, but have Gotham beta 3 installed also just for testing etc...
I'm also using the Mele F10 remote, all configured by changing the generic.kl file in the root menu of the ouya.
However, I've just noticed that in the Gotham beta 3 version, the context button on my remote doesn't work, but it does in SPMC?
Anyone any ideas? Does Gotham have a slightly different config for buttons etc?
DMN1981
Hi All,
Anyone with any ideas?
I've used the key map editor to map it to another button, but it's really annoying after using the same button for nearly 7 months!
Also, when I press on one button on the remote, the selector on the screen goes nuts, and won't stop jumping around!
This is the only gripe I have with Gotham Beta 3 at the moment!
Please help?
Dmn1981
Also I have just noticed that I went to add a new source via the file manager, and when the virtual keyboard came up, I could use the letter keys on the Mele F10 Pro remote, but I couldn't go up, down, left or right with the arrow keys and move the selector on the virtual keyboard on screen?
I think I went to the right section in the key map editor, to map keys to the virtual keyboard under the file manager window?
I'd love some help getting my remote to work like it did with Frodo!! :-(
dmn1981
debug log (wiki)? It should work from what you've described. I don't have a Mele remote to test with, though.
