Full Version: remote works in XBMCBuntu, not in Mint 13
I have a cheap Chinese keyboard type remote that works out of the box with xbmcbuntu, however I had issues with getting audio iin the xbmcbuntu desktop so I opted to install Linux Mint 13 Maya. I was then able to get audio but now I have issues with the remote not working in xbmc.
I am almost certain this is not a windows media remote nor nothing requiring lirc, as I have used it on Raspberry Pi as well as xbmcbuntu with no configuration
Questions
Is there some support for remotes in xbmcbuntu that does not exist in ubuntu or Mint?
If I want to go back to xbmcbuntu, how would I fix the audio in the xbmcbuntu GUI? Iget audio in xbmc but what I want is chromium browser to be launchable from xbmc with sound using advanced launcher
I enabled logging while running xbmc and pressed some buttons including volume which is the only key that worked here is the result:
1:52:05 T:3047426432  NOTICE: Enabled debug logging due to GUI setting. Level 2.
01:52:05 T:3047426432   DEBUG: ------ Window Init () ------
01:52:17 T:3047426432   DEBUG: ------ Window Deinit (Pointer.xml) ------
01:52:23 T:3047426432    INFO: LIRC Initialize: using: /dev/lircd
01:52:23 T:3047426432   DEBUG: Failed to connect to LIRC. Retry in 40s.
01:52:24 T:3047426432   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-i486-linux.so)
01:52:24 T:3047426432   DEBUG: Unloading: ImageLib-i486-linux.so
01:52:24 T:3047426432   DEBUG: CWinEventsSDL::CWinEventsSDL - XKb symbols pc_us_inet(evdev)_terminate(ctrl_alt_bksp)
01:52:24 T:3047426432   DEBUG: CWinEventsSDL::CWinEventsSDL - m_bEvdev = 1
01:52:24 T:3047426432   DEBUG: Keyboard: scancode: 7a, sym: 00ae, unicode: 0000, modifier: 0
01:52:24 T:3047426432   DEBUG: OnKey: volume_down (f0b8) pressed, action is VolumeDown
01:52:24 T:3047426432   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
01:52:24 T:3047426432   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
01:52:24 T:3047426432   DEBUG: ------ Window Init (DialogVolumeBar.xml) ------
01:52:25 T:3047426432   DEBUG: Keyboard: scancode: 7a, sym: 00ae, unicode: 0000, modifier: 0
01:52:25 T:3047426432   DEBUG: OnKey: volume_down (f0b8) pressed, action is VolumeDown
01:52:25 T:3047426432   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
01:52:25 T:3047426432   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
01:52:26 T:3047426432    INFO: CheckIdle - Closing session to http://feeds.xbmc.org (easy=0xb4500468, multi=0xb4509420)
01:52:26 T:3047426432   DEBUG: ------ Window Deinit (DialogVolumeBar.xml) ------
01:52:27 T:3047426432   DEBUG: ------ Window Init (Pointer.xml) ------
01:52:28 T:3047426432   DEBUG: ProcessMouse: trying mouse action leftclick
01:52:28 T:3047426432  NOTICE: Disabled debug logging due to GUI setting. Level 0.
